kf 40 valve
Jake Wells
Real name: Jake Wells
kf 40 valve
Post by Jake Wells » Mon Mar 31, 2014 2:42 am
I have bought this kf40 valve I heard they were really good for throttling. the problem is it doesn't have a knob for controlling does it run on power or is it manually operated?
http://www.ebay.com/itm/111312363090?ss ... 1439.l2649
― Nikola Tesla
charlie_mccartney
Real name: Charlie McCartney
Re: kf 40 valve
Post by charlie_mccartney » Mon Mar 31, 2014 2:53 am
In the listing it says "24VDC" that suggest that is uses 24 volts, DC. So yes, this does use electricity to control it. A simple google search could have answered your question.
Charlie McCartney
charlie.mccartney1104@gmail.com
charliespersonalproject.weebly.com
Re: kf 40 valve
Post by Chris Bradley » Mon Mar 31, 2014 6:34 am
Looks all pneumatic to me. It needs a high pressure air circuit and is either on or off. Useless for fusor work.
When posting, do not create a post that relies on an ebay link. It will die, and the value of the post will then die too. Also, create a title that summarises the post to facilitate searching.
