AC Window Unit Compressors
- Rich Feldman
- Real name: Rich Feldman
Re: AC Window Unit Compressors
Monroe,
I'm eager to see vacuum measurement results from one of your little chiller compressors,
and from two in tandem to see if that makes a difference.
Am guessing that in many designs, the vacuum is limited by the compression ratio and the need for compressed gas to push open a reed valve.
Here are some pictures from a trephination experiment I did in early 2005. There might be more info about the valves on websites like "sam's laser faqs" or belljar.net.
- Monroe Lee King Jr
- Real name: Monroe Lee King Jr
Ahhh yes indeed but in my book there's just no better way than to make things yourself to get a root understanding of the nature of things. It allows incite into ways of doing things others wont try because they don't understand the true nature of it. For instance the scientist vs the engineer I'm a bit of both + mechanic. I make my own chemicals, telescopes, microscopes and tools. The rocket guy's feel the same way about me, but I've gone higher and farther than most wanna be rocketeers and spent far less money doing it.
I know for instance if you want to get to space cheap you fly a balloon to high altitude and launch from there. For some reason the rocket guy's just don't like it? Makes absolutely no sense to me to launch a small rocket from the ground!
Makes no sense to me to spend a dime on a fusor demo either! I know for a fact I can get plasma with my set-up here for nothing! Can I pull a medium vacuum with this set up maybe not! But maybe?
I know refrigerator/freezer piston compressors wont work! But A/C window unit rotary pumps with the proper oil might! I can easily set up an automatic oiler to keep the pumps alive and put in a gas ballast valve between the 2 stages. 2 things the average experimenter leaves out! I don't see experiments with these in this configuration with the proper oil!
I also know there are lots of kids out there that could get these pumps that have no chance to get a real pump. I was over 20 years old before I could afford a real pump! I know I can make a demo fusor with this setup and so can others less fortunate! I also remember I was at my peek of learning capacity when I was 13 years old! I was lucky a neighbor noticed I was sharp and helped me attend collage when I was 13 because I was into physics so deeply at that age. I want others to have a chance that's all. Being in collage at 13 is a bit weird for a 13 year old but cool indeed. Perhaps some other kid will do this and get noticed?
I'll get around to the man sized fusor soon enough. This one's for the very young to try with pocket change.
Monroe
Monroe
Last edited by Monroe Lee King Jr on Fri Sep 06, 2013 12:13 am, edited 1 time in total.
Today's the Day! We go into Space!
@Rich
I see what you have there. That is a piston pump correct? How did your experiment go with that? The rotary style pumps don't have any valves These A/C window units are rotary compressors and have a much higher chance of working at lower pressures.
Monroe
By the way it's super cool to see the guts of a pump like that isn't it!
The limit is how close a tolerance you can hold, the smaller the better and the vapor pressure of your oil. There are other factors but these are the main 2 the true limit is in the oil if you can build the machine (pump) good enough.
Oh and by the way so far I don't know how low I can pump with these compressors. I can pull 29 inches with a single pump but I found out I can't measure any lower than that with my current gauge (I guess it has a small leak) I discovered this last night as I was cleaning these with mineral oil (in preparation for higher grade pump oil) I pinched my line and I could see bubbles coming from the gauge side if I held the pinch just right. If I pinched it off all the way no bubbles! So yeah my gauge leaks a little.
I don't have a swaging tool to mate up the lines for soldering just yet. I can make one on my lathe as I don't need many sizes. You could make a crude one easy enough from a flairing tool or buy a simple one for $20 but I have a lathe so I'll just make one. I'll post some photo's of the swaging and soldering process soon.
I'm going to use a saddle valve ($5 each) for the oil leak and the gas bypass valve.
Monroe
- Mike Veldman
- Real name: Mike Veldman
Thanks for the personal history lesson it helps. Perhaps you should have mentioned this was a "play time" project and saved yourself our attempts to save you time and trouble. I played some in the 70s running refrigeration compressors as engines. Both using actual steam and freon 504 as the working medium, heated by solar collectors and parabolic dish boilers. Some success in both cases, even made electricity from a sealed unit motor run as a generator. The scroll compressor is much easier to use in this application. So, now I'm kinda interested in what you turn up, as I'm sure are others, since we all seem to have natural child like curiosity.
mike
mike
I tried to contain myself, but I escaped.
On fusor III, I was still in "make-it-myself" mode, trying to hack stuff. Good vacuum stuff is hard to hack. I came to the table with a few years of low level vacuum experience, but really dug into the texts related to conductance and took the "Bell Jar" subscription for its entire run.
Our local scrap yard had a ton of large SS 316 steam fittings. Among them I found 2 - 8" diameter blank offs that used 8 - 3/4" bolts! Cost for the pair?.... $40.00. Not to be stopped by a web of solid metal, I struggled to use my milling machine and rotary table to hog out the 1" thick circle required to turn those monsters into rings to allow me to TIG weld my two Braun 6" hemispheres to make my SS fusor III chamber. Over a 2 week period and about 100 hours work, I fashioned fusor III. (A week's vacation from work - Full time and attention) The machining, drilling, and welding, it was a real chore. Fusor III was my first fusing fusor. It suffered from a plethora of leaks and other cheesy, but cleaver, bothers. I sealed its flat mating surfaces with pure indium wire and this was good enough to let me do limited fusion. Even the view port was home made. I was proud and would be the first amateur to do fusion in a Farnsworth fusor. On its best day, Fusor III could kick out about 200,000 n/s but was more often in the 100k n/s range.
I limped along until 2003 when I had enough hardware for fusor IV. This time I was going to do it right. A pair of 8" professional conflat rings were picked up in 2001 off e-bay for $45.00 each. Another pair of Braun hemispheres were purchased in 2002 for ~$100.00! I purchased mostly swagelock gas fittings and valves all for about $100.00. The final item, a good 2.75" conflat window with a 1" clear aperture cost me $20.00 at an HEAS fleamarket in 2003. I was set for only a little over $300.00 to build a proper, professional fusor! No tedious machining this time except for the boring of the port holes in the hemispheres and a bit of welding....A snap!
On the vacuum end, I had determined to use a diffusion pump with my mechanical pump this time. (Fusor III was 100% mechanical only using a professional 5CFM Precision lab pump, but did utilize the good offices of a Lesker micro maze. Still, I wasted a lot of D2 in getting fusor III to perform with this less than adequate vacuum system.) I found a nice little air cooled diff pump at HEAS 2001 for $50.00, so, I was all set.
At first pump down of the new Fusor IV chamber, I was stunned to hit 10e-5 torr in mere minutes! WOW! Having the right stuff made all the difference. I learned my lesson. Whenever I think of machining what I need out of some kludged metal item, I think again and either wait to seek out what I need made for the purpose over time on e-bay, hamfests or fleamarkets or let go of the cash, if desperate. I do less machining and get better results. Fusor IV went on to exceed 1.5 million n/s a few years ago and can regularly hit nearly a million n/s.
You can't beat having the right stuff based on years of vacuum technology advancement in the art. Understanding vacuum technology takes a lot of self-directed reading as well. One learns that 1/2" vacuum lines will never pump well at the scientific level and that if you have to rely on gobs of vacuum greases to seal your vacuum, you are doing something really wrong.
If one is willing to burn off a lot of time, spend little money and have a gross underperformer as a result then have at it. The ultimate success of a fusion project proceeds as the inverse square of the number of home spun kludges in the system.
We shall see indeed. Hey so far I ordered 2 saddle valves and some oil so I've got $20 invested and about 2 1/2 hours. Most of my time right now is researching so the little time I've spent playing with these compressors is a good break. By the way the pumps pulled much faster after sitting overnight with the mineral oil in them. Now I need to make the Pirani Gauge so I can see what I'm really pulling. Making this gauge http://www.drkfs.net/pirani.htm I'll have to order a 1A meter from fleabay for $5
Monroe
Monroe
- Real name: Ross Moffett
Harbor freight muktimeters make great cheap panel meters.
- Rich Feldman
Hi Monroe.
Re. the Pirani gauge, there are many ways to make 'em. Perhaps even easier than the one in your DrKFS link is to open a miniature incandescent lamp, or take a glow plug, and expose the filament to your vacuum under test. Reminds me of your proposal to turn an ordinary vacuum tube into an ionization-type vacuum gauge.
Here's one thread (talking about both) that came up right away in fusor.net archives.
viewtopic.php?f=10&t=3544&p=22917
Are you trying to copy the DrKFS design so closely that you can use his calibration table, with no other vacuum reference?
Then (with all due respect) I wouldn't expect absolute accuracy closer than a half-octave, maybe a full octave.
Did DrKFS post any data about design repeatability, or sensitivity to details like wire diameter?
IMHO, factor of two errors in pressure measurement (if stable) would be pretty minor as you characterize and operate a fusor.
As for displaying pressure values, from nonlinear voltage or current measurements.
Let's push Nick Peskosky to realize the open-source digital solution he mentioned in his post today ("06SEP13").
I once took an analog meter & made a nonlinear scale card, not unlike DrKFS's solution, and reported it here: viewtopic.php?f=10&t=4047&p=21455
Yeah your right! I used one I got at Autozone on a little bench supply I made out of a PC Power Supply for fun. Has a 24v variable 1.5 amp and the rest you see there. Even has a standby and active mode.
@Rich thanks for the links! Yeah, I was kinda thinking about using his calibration. However I'm still looking at other designs. I like the glow plug idea even better using the platinum wire and already made for $7. Still looking! Keep the info coming!
Monroe
Monroe
You can use a thermistor to measure vacuum. There are plans out there. Here is one design of many. Of course you need something to calibrate it.Rich Feldman wrote:Hi Monroe.
http://www3.telus.net/schmaus2/vacf/thermis.html
Looks like all these charts look pretty much the same too! Thanks! Yeah I can work something out. I have the 2 pumps running together now and I received the vacuum oil today and I primed them with it. Should get the saddle valves Monday or Tues. So now I need the gauge to test them With both pumps running it does increase the cfm for sure because the gauge I have now drops like a rock to 29 inches (where my gauge leak stops me from getting 30) I want the gas ballast valve in there before I go for a long run test.
I found a board to mount them on still need to make up a good catch cup for expelled oil and the oil drip for the intake.
Naturally, the 29-30 inch readings are absolutely valuless in the technical sense as you could still have up to 1000 times too much remaining air in the lines to get to star mode. Such a gauge really isn't worth having when qualifying any sort of scientific, technical forepump as it tells you nothing about the bottom end, only that you have some sort of vacuum of totally unknown level.
For sure the bourdon gauge is just a mechanic's tool to determine rough vacuum. It does mean the pumps are working and I can can get a rough idea of cfm (how fast the gauge drops) it is handy for beginning to look at vacuum. I now have to construct a valid gauge to determine how deep the rabbit hole goes. That's next on the list.
Monroe
Monroe
Ok here are the saddle valves in place. The thing to remember about these valves is they pierce the tube and are now needle valves with the tube as the seat so you have to barely pierce the tube and when you close the valve Do Not apply much pressure to close it. Keep an eye on the handle position when closed because over time if you close to hard it will move and at some point you will run out of needle for a proper seat! So the one on the top is the Gas Ballast valve between the 2 pumps and the one on the suction just above the dryer is for the oil drip cup to keep the pumps lubricated. The pumps are filled with oil so as long as you have a little oil in your exhaust you are getting lubrication. It also helps the pump seal and pump lower as the oil is the seal in the pumps.
Ok well! I've got the pumps running as good as they will run. I have for sure discovered the gas bypass is absolutely necessary! I can tell by the sound of the pumps you need to run for a bit with the gas bypass open and then close it after the pumps warm up. To explain I'll say the fore pump cavatates (sounds like it has beads in it) until you get up to operating temp/pressure and then when you close the bypass the pumps quiet down to a nice hum. If you don't run with the bypass open for a while it will sound like that no mater what. That means to me if you run 2 together a bypass is required to get the moisture out. Running these pumps without an oiler on the inlet would also not work very well either as I can tell also by the sound of the pumps they like the oil.
Now to build the Pirani gauge and see if the effort was at all worth the end result.
Monroe
Monroe
