I believe I've heard of JB weld and similar epoxies being used in high-vacuum environments for lower quality fusors and cyclotrons. Personally, I see a major offgassing problem with this. Does anyone know if it could hold up to the task, just for use in a bare-bones fusor or for other high-vacuum equipment? Thanks!
-Ryan
Is JB Weld High-Vacuum Safe?
- Real name: Ryan Atkinson
You are now aware of your breathing.
Re: Is JB Weld High-Vacuum Safe?
Ryan
Read this forum
there is plenty of info
Read this forum
- Real name: Jeroen Vriesman
Nasa has an outgassing database:
http://outgassing.nasa.gov/index.cgi
Go to search and just type "JB weld" in the box.
What is also important is the high temperature it can handle, it means you can do some bake-out.
Curing temperature, material thickness and surface area exposed to the vacuum is also important.
I have used "Hysol 9497", cured for one hour at 100 deg.C and then used it in vacuum (bake-out at 100 deg. C for 2 hours), no problem reaching < 1E-5 mbar.
Thanks, this was very helpful.Jeroen Vriesman wrote:Nasa has an outgassing database:
-Ryan
