How to minimize backstreaming from diffusion pump
Jeff Robertson
Post by Jeff Robertson » Fri Feb 24, 2012 11:41 pm
Apologies if this has already been addressed, I've been abusing the search function but haven't found a direct answer to this question.
What's the best way to connect a diffusion pump to vacuum chamber? From what I've read/heard from others, connecting the diffusion pump directly to the chamber is bad news and will definitely result in some oil backstreaming. What's the most practical way to minimize this oil backstream? I've seen a lot of talk about cold traps, but I don't know if this is the most viable way to go, or even how exactly to make a cold trap. A couple articles I was reading mentioned using liquid nitrogen as a cooling agent in cold traps, which seems way more complicated than anything I've heard anyone do.
Thanks as always.
Jeff Robertson
Edit - Don't know if it's worth mentioning, but I'm using DC-704 diffusion pump oil.
SteveHansen
Re: How to minimize backstreaming from diffusion pump
Post by SteveHansen » Sat Feb 25, 2012 12:20 am
Most diffusion pumps have some sort of optically dense (can't see straight line through it) baffle which helps considerably. You may also see a water cooled cold cap over the upper jet. A baffle will slow the pump down a bit but that's actually good as it reduces the amount of gas needed to maintain pressure in the fusor and it creates a pressure drop that helps to keep the pump inlet in molecular flow while the chamber is in transition flow.
DC-704 is a good, low vapor pressure fluid. Santovac is better but at many times the price.
Finally, when you are flowing gas, the outlet of the chamber should be in transition flow as opposed to full molecular flow. That has a ballasting effect and will also help to minimize any backstreaming.
A lot of Varian's pre-turbo leak detectors didn't use a cold trap. Just baffling and low vapor pressure fluid.
Carl Willis
Real name: Carl Willis
Post by Carl Willis » Sat Feb 25, 2012 12:26 am
Hi Jeff,
I have successfully used DC-704 oil in diff pumps with no traps, down into the 1E-7-torr range.
A lot of older directives mention the need for traps, because older hydrocarbon pump oils continuously broke down into volatile cracking products and most uses benefited from chilled baffles or traps. That is no longer the case. Polyphenyl ether oils and silicone oils are more common now, and are generally heat- and even oxygen-stable.
Some vacuum processes are sensitive to trace contaminants from modern pump boilers. Any proper diff-pumped UHV (< 1E-8 torr) system will still include baffles or traps. The purpose of the diffusion pump in a continuously-pumped fusor is to improve speed over mechanical pumps at operating pressures in the millitorr range. This is a very modest requirement, well-suited to smaller diffusion pumps using cheaper oils and no baffles or traps.
Carl Willis
TEL: +1-505-412-3277
Jeff Robertson
Post by Jeff Robertson » Wed Feb 29, 2012 3:57 am
As always, thanks for the informative responses guys.
Carl, your success without cold traps is relieving to hear, as I was dreading having to learn/implement yet another additional piece of vacuum technology. I have some time now so I want to clarify how my vacuum system will operate. I am working with a glass bell jar, with the diffusion pump originally planned to be mated directly to the base. If one was to sit on top of the inner grid, they would be able to see into the diffusion pump (but not very far). The pump is currently locked away in a lab which I won't have access to until monday, so unfortunately I can't inspect it and give you any information on its optical density. I am fairly certain, however, that vision directly down into the pump is impeded by a baffle.
I tend to suck at describing things with words, so I included a picture (taken from a paper I'm writing) of the vacuum system I plan to build. Additionally, I included a picture of my diffusion pump, which was kindly sold to me by a fellow member of these forums. I've searched long and hard for more information on the pump, but sadly I don't think Edwards supports or makes this specific type of pump anymore.
So, based on the images I attached, would you guys still say it's safe to push forward without a cold trap?
Cheers,
Jeff Robertson
Edit - The image of my vacuum system wasn't showing up, so I re-uploaded it as a jpg to see if that would fix it.
SteveHansen
Post by SteveHansen » Wed Feb 29, 2012 11:49 am
I don't see any kind of baffle.
I would recommend putting in a simple optical baffle. The quickie figure below shows one that works. Make 3 aluminum disks that just fit into the pump's inlet. You can cut them with a hole saw. Then use the saw to make two "mousebites" in each disk Cut these so that when the three pieces are stacked on top of each other at 90 degrees you can't see through the stack. Drill a hole in the center of each for a 1/4-20 bolt. Stack them so that there's about 1/4-3/8 inch between them and they sit just above the top jet when inserted into the pump.
This is the type of baffle used in the first DP I ever owned - one made by NRC. I've never used a chilled trap but have used some kind of optical baffle on each pump.
Steve
SteveHansen
Post by SteveHansen » Wed Feb 29, 2012 12:35 pm
One other note, Jeff. I don't see any kind of isolation/throttle valve at the diffusion pump's inlet.
Post by Richard Hull » Wed Feb 29, 2012 2:28 pm
You will definitely need a throttle valve between the diff pump and your chamber, as Steve noted.
I am currently unaware of any successful fusioneer who has ever used a cold trap and no one has announced using even an optical baffle, though these are sometimes part of a surplus diff pump's assembly. The key is to use the best fluid you can afford and not to make any mistakes during operation and shutdown of the diff pump. Check this forum's FAQs for proper operation in a fusor environment and a lot more data on diff pumps in general. (relative to the fusor of course)
viewtopic.php?f=25&t=4142#p21550
I see you have a water cooled pump. This more or less lashes you to the yard arm of having a continuous flow of water from the mains with associated drain or developing a cooled, closed circuit, recirculating water system. Most fusioneers, (I think 100%), opt for an air cooled diff pump system which is a time and effort saver.
We are not vacuumists, (vacuum heads), which has a concomitant purity clause associated with the rite of passage. We can have contaminants and other garbage in our vacuums that would frighten the vacuum purist.
We use the diff pump to get somewhere in the warranted 10e-5 torr range. To a deep vacuum guy this is "filth city". Since we work in a flowing gas, (deuterium), environment in the 10e-2 range, the filth is only 1 part in 1000 or, the fusion fuel out numbers the filth 1000 to 1. This is a highly acceptable level of operation.
So, bottom line, start with as clean a system as possible, use the best diff pump fluid you can buy and try for an air cooled pump and you are pretty much past any vacuum issues in fusor operation. We are here to do fusion and not spend a lot of gear grinding time and anguished moments over an ancillary vacuum system. Give your vacuum system a lot of attention up front and you won't be fiddling with it unduly during operation.
Some folks think I am in charge here. Far from it. What knowledge I impart in this amateur fusion quest comes from 14 years of being "lashed to the wheel", having personally committed all the sins and made all the mistakes, poking around in the fog of amateur fusion. We all have fashioned this site through a good deal of trial and error, learning and sharing as we went along the path.
SteveHansen
Post by SteveHansen » Wed Feb 29, 2012 5:17 pm
I'll agree and disagree here. True, the vacuum requirements for a fusor are pretty trivial in terms of pressure and contamination control. Far more critical are the niceties of operation: it's very easy to really mess up a diffusion pumped system if you stall the pump. Proper throttling and control of the gas feed are very important.
That said, if better practice can be achieved by simple measures, then incorporate them. Most of my vacuum needs do not significantly exceed what's needed of a fusor. But, I don't leave finger prints on the wetted surfaces of components, I don't own any vacuum grease and I always make sure that I can't see the top jet of a diff pump from the chamber.
But then, I'm a vacuumhead.
Steve
Post by Richard Hull » Wed Feb 29, 2012 6:45 pm
My admonition about starting with a clean system will cover the neatness and the throttle valve will cover the optical exposure of the jet stack to the chamber while in operation.
Note: The fusor is always operated and gas flow only attempted when the throttle valve is barely cracked open, (jet stack totally invisible.)
I have my right angle throttle valve mounted directly to the Diff pump and then take off at a right angle a 6 inch long 1.5 inch diameter SS flex hose in another turn onto the chamber. No one working a fusor should go from pump to valve to chamber in a straight stacked fashion unless they are looking for trouble.
Again, at the higher vacuum levels we are looking for some naturally installed reduced conductance. After all, in operation, we will have about a 1/32 inch or less opening diff pump-to- fusor chamber as we strangle the diff pump to where the micro slow gas leak into the fusor is maintained at about 8-20 microns; about where most mechanical pumps are bottoming out. This is why you can certainly operate a successful fusor with just a very good mechanical pump coupled to a zeolite trap, provided you are willing to waste a little deuterium at start up.
SteveHansen
Post by SteveHansen » Wed Feb 29, 2012 7:36 pm
Violent agreement - all good approaches to proper practice.
In the industrial world a lot of people question why throttle valves, even for large pumps, are only spec'd from just cracked to about 10% open. Max open for control purposes may be well under 10% open or less than 5% of the pump's rated speed. This is simply because you only need full pumping speed to reach base pressure and then you just want to sip gas during the process cycle.
Same with a fusor, you need to throttle the pump way down so that you keep the pump inlet in molecular flow, the chamber is at the right pressure for the plasma and you don't eat up your D2 supply.
Q = S x P rules.
Steve
