Diffusion Pumps 101
chad ramey
Real name: Chad Ramey
Re: Diffusion Pumps 101: Jet Assembly
Post by chad ramey » Sun Jul 03, 2011 7:39 pm
Wow....just simply fantastic. The craftsmanship exemplified thus far is astonishing! I look forward to seeing how it works.
-Chad
George Schmermund
Real name: George Schmermund
Post by George Schmermund » Sun Jul 03, 2011 9:42 pm
The boiler section of the pump has been the easiest part so far. It took about 5 minutes to setup and braze a 1/4" SS bolt to the bottom of the pump body and another 10 minutes to cut up a vegetable can from the pantry and then put some holes and grommets in it. The trimmed can was used like a cookie cutter to make the Fiberfrax insulation pieces. The rope heater was wrapped flat against the bottom of the pump body and compressed into place by the lid from the can, which also had a hole in the center. This formed a sort of spool arrangement to keep the heater coils tight and flat. The leads were then fed through the grommets and the whole boiler assembly tightened up with the bottom nut.
More to come.
richnormand
Real name: rich normand
Post by richnormand » Sun Jul 03, 2011 10:17 pm
Very, very nice George!
Can’t wait to see how well this will work out.
Most of the stuff seems to be stainless steel and such. Is the tin can part of the heater a possible problem? They (tin cans) tend to have coatings inside (plastics or flash metals) and soft welds at the seams that could be an issue even if it is not in the vacuum part of the pump? I assume your temp will be low so that is not such an issue.
Still, the eye candy value alone has me glued to the photos.
Looking at the inventiveness, particularly using common utensils, is in the best traditions of Rutherford's work and "Building scientific apparatus" first edition....
Carl Willis
Real name: Carl Willis
Post by Carl Willis » Mon Jul 04, 2011 2:04 am
Modern art with "found objects"! Nice work, George.
I can't wait to see the results of your trials. What will be your pumping fluid? Extra-virgin olive oil?
Carl Willis
TEL: +1-505-412-3277
George Schmermund
Post by George Schmermund » Mon Jul 04, 2011 7:46 pm
Thanks for all the encouragement, guys! If I get some time today I'll finish up the foreline and braze it into the pump body. The final effort will be to shape and install the cowling and cooling fan(s).
As far as the can used for the boiler heat shield goes, there is no seam, but there is a very thin coating on the inside surface. I'll carbonize the coating with the torch and then clean up the can with some Scotch-Brite and Lysol PTBC. I'll also probably add a thermocouple to the bottom of the boiler. This will allow me to run some temperature/ pressure curves in the future.
I do remember something about distilling olive oil and using it in a desperate act as a diffusion pump fluid. I think it was in The Amateur Scientist column back in about 1960 or so. Anyway, I'll stick to DC 704 for this project.
Post by Richard Hull » Tue Jul 05, 2011 2:02 pm
Looks like it ought to work. You have poured the work into it. If this works out it will offer a cheap way for the DIYs to make a small air cooled pump more suited to a small fusor rather than have to pay the premium often seen on these small manufactured units.
John Taylor
Post by John Taylor » Tue Jul 05, 2011 4:13 pm
Very nice workmanship! I can't wait to hear how well it works, I would like to emulate this as it looks like a great project.
George Schmermund
Post by George Schmermund » Tue Jul 05, 2011 8:56 pm
The pump body is basically finished at this point. Next is the cooling system. I've been thinking about different configurations and they all seem to have their own merits. I'll put a few thermocouples at the points where I'm interested in seeing the effects of the different methods.
I've added another pic of the boiler so that it's clear how the rope heater is installed and kept under control. It's important that the heater remain in intimate contact with the bottom of the boiler.
After torching the can to red heat to remove the plastic film on the inside and then Scotch-Brite scrubbing it clean, I decided to retorch it to get that 'gun metal blue' look. This is my concession to steampunking and Carl's comment about "art".
richnormand
Post by richnormand » Tue Jul 05, 2011 9:29 pm
Would one or two computer CPU fans with a metal shroud following the curve of the main body be adequate? If not a ThermalTake liquid CPU cooler might do, with a small copper tube spiral on the outside.. It comes with its own pump, radiator liquid-to-air heat exchanger and all the trimmings. I used them for cooled pmts, peltier cooled ccd detectors and ccd camera. The old models are available on ebay for cheap and can displace lots of heat in a small turn-key package.
DaveC
Post by DaveC » Wed Jul 06, 2011 1:02 am
George - beautiful!
You combine, art, science, practical engineering and a great sense of humor. Impressive work.
(Lots of real talent amongst those on this board.)
