Turbomolecular Pump Question
Hey all. I've got a TMP-50 turbomolecular pump for my fusor but I have no idea what to use to connect it to a vacuum system. Could use a little help.
Re: Turbomolecular Pump Question
Jake
follow my link that i put in the thread about "simple turbo pump controller" as that thread is for two phase pumps you will need to follow my link as the TMP50 is three phase
I'm sorry, I don't think I was clear in my last post. I have a pump controller for it already, but I don't know how to physically connect the pump to a vacuum system. I'm new at all this stuff so if it's a simple thing to buy a connection for it then I apologize. =)
It is a simple yet complex question,
Simple in that the turbo pump goes between your backing pump and the chamber...
Complex in that each Fusor is different, and we don't know what you have to work with or want to achieve.
Fortunately this has been addressed thoroughly on these forums and in other literature if you do some searching and reading. The manuals for these pumps have lots of good information as well. Make sure you have a deep understanding of everything involved before you fire it up. Once you have that understanding then you will be able to answer this question yourself better than any of us could for you.
Turbo pumps are also finicky beasts, I have a crashed one sitting on a shelf as a mute witness of past failure. Don't rush things, or you may end up with a similar trophy.
-Chris
-Chris
Nothing beats the simplicity of the diff pump or its overall indestructable nature with no moving parts and no controller needed, it is the pump of choice for the amateur vacuumist working in fusion. We have little need for a laboratory grade, ultra pure vacuum often afforded by the turbo when actually in operation in D-D fusion.
Still, if one comes your way ultra cheap with full controller and cabling, it is worth the changeover, especially if you want to do other experiments outside of fusion that demand the kind of vacuum it provides.
