Is this the right pump forStar Mode
ggombert
Re: Is this the right pump forStar Mode
Post by ggombert » Tue Mar 08, 2011 1:19 pm
The small Edwards diff pump in the picture below was picked up on Ebay for ~$200.00, it pumps down fast in about three minutes to below 10-5 torr and would be a good pump to consider as Fusor chamber high-vac pump.
Glenn
viewtopic.php?f=25&t=3909#p24971
richnormand
Real name: rich normand
Post by richnormand » Tue Mar 08, 2011 5:23 pm
Yes, I do.
Anything specific you are looking for?
Nikelopez
Post by Nikelopez » Tue Mar 08, 2011 10:45 pm
Well basically, I just need an instruction manual for this pump.
richnormand
Post by richnormand » Wed Mar 09, 2011 2:17 am
OK Nikelopez. "B" but most applies to the "A" unless you are planning a full rebuild.
Leybold_TRIVAC_D16B-D25B_Operating_Instruction_Manual_2.pdf
(715.52 KiB) Downloaded 130 times
Nikelopez
Post by Nikelopez » Mon Mar 14, 2011 8:49 am
@richnormand
Thank You, So much.
-Nike
