Veeco diffusion pumps
fpg
Post by fpg » Sat Apr 17, 2010 5:11 pm
reasently found these diffusion pumps on ebay:
http://cgi.ebay.com/P65618-Lot-2-Veeco- ... 5ad8a9c026
Just wonder if anyone have any experience with this kind of pump and are they any good?.
Linda Haile
Re: Veeco diffusion pumps
Post by Linda Haile » Sat Apr 17, 2010 7:02 pm
These should be ideal for the average fusor. They are about as simple as they get, being air cooled.
Steven Sesselmann
Real name: Steven Sesselmann
Post by Steven Sesselmann » Mon Apr 19, 2010 12:24 am
ditto..
I agree with Lyn, these should clean up and work well, as long as they have decent air circulation, hassle free without water cooling.
Just make sure that they have the baffles inside, as it can't be seen on the picture.
Linda Haile
Post by Linda Haile » Mon Apr 19, 2010 12:31 am
They will need a good clean, acetone, IPA. Getting the two means you should be OK for spares, but these are pretty indestructible anyway.
Jerry Biehler
Post by Jerry Biehler » Mon Apr 19, 2010 4:14 am
I have bought quite a bit of stuff from these guys. Recently got a new 2 into 1 800um fiber cable that will combine my two 40w fiber coupled laser diodes to one output. Could be fun!
One thing good about them they do pack well using foam in place packing.
fpg
Post by fpg » Mon Apr 19, 2010 7:53 pm
I won the auction!
Now I only hope that the vulcano dust disappears from europe so the pumps can arrive by plane.
dbrown
Post by dbrown » Sun Jul 04, 2010 12:11 pm
Can't say one way or the other how well they will work but I have used a number of water-cooled units and really liked them. I might suggest that you use a small fan to cool the fins - DF's pumping efficiency depends highly on the ability to convert the vapor back to liquid. Also, I fully agree with the previous posters cleaning method – very good choice of chemicals for cleaning old DF oil out (very safe chemicals solvents, too!)
That said, remember you don’t know what the original person pumped so assume the worst and treat the waste liquids from the pump as full of toxic heavy metals or other bad guys. That is, work outside, put the waste into containers that you throw away, and use gloves.
