Looking for a High voltage, High cure temperature suitable for high vacuum two part epoxy resin. I need to repair a detector feedthrough leak. Feedthrough are fixed using a two part epoxy resin (light brown colour) which is cured at hight temperature (above 200 deg C). High voltage (above 10 KV) is applied to this feedthrough. inside detector should be evacuated to 1x10^-6 . A picture of the detector with feedthrough sealed using such epoxy is attached.
Any recommendation?
thx
High voltage, High temperature vacuum tight two part epoxy resin
- Jim Kovalchick
Re: High voltage, High temperature vacuum tight two part epoxy resin
Hysol 1C
I have used it in a HV feedthrough. The only issue is that it does not tolerate exposure to plasma.
- byron addams
- Real name: byron addams
I used some of the steel reinforced jb weld and it works perfectly doesn't outgass much and tolerales plasma fairly well.
Trying to keep the magic smoke from getting out.
- Real name: Robert Mendelsohn
I would recommend Hysol EA1C. It's an incredible epoxy that fits the bill for the properties you mentioned, and it relatively inexpensive.
