Turbovac 150/360 cable diagram?
Post by Jerry Biehler »
Local university gave me a few Leybold turbos the other week, Got another 50 as well as a 150CSV and a 360. I need cables for between the NT20 drive and the turbos. Does anyone have the wiring diagram? This would have a AMP CPC 14 on one end and a octal socket on the other. Cant find any info online. Trying a contact I have at Leybold but not sure on that one.
-Jerry
Re: Turbovac 150/360 cable diagram?
Post by Rex Allers »
Here's some info I saved from 2017. The original (1st part) came from a post by John Futter here somewhere. I didn't save the link but title and date is shown. After John's part, I added some more info from my own measurements. Looking at this now, the info for the controller side pins 5 A & B is confusing. The reversal after the words 'actually' may be my notes from measurement but I don't remember and can't find where I stashed the turbo and cable to check it now.
FWIW, use at your own risk.
Re: Turbopump maintenance
Postby John Futter » Thu Jun 27, 2013 12:03 am
The TMP360 pump pin out is as follows
standard Octal tube socket
pin 1 =earth
pin 2 = pump select (the 360 has a different resistance compared to the 150 so the controller knows which pump is connected)
pin 3 = thermal switch
pin 4 = not connected
pin 5 = not connected
pin 6 = Phase A in
pin 7 = Phase B in
pin 8 = Phase C in
connections on the controller
phase A goes to 1A and 1B
phase b goes to 2A and 2B
phase C goes to 3A and 3B
Earth goes to 4a and 4B
Thermal switch goes to 5A actually 5b
Pump select goes to 5B actually 5A
Rex notes sep 15, 17
Possibly not quite right
From Turbovac 150CSV measurements...
A, B, C = approx .5 ohm DC between any -- nothing to other pins (delta conn)
1 is connected to case; don't see anything to other pins
2 seems open on 150CSV (re gnd)
2-3 is shorted at ambient
Looking at Turbotronic driver box...
Output connector has separate pins for each phase + and -
The A pin pulls negative through 2N6284 Darlingtons
the B pin pulls positive through 2N6287 Darlingtons
For each phase the cable ties A & B pins together for each phase
Phase A = 1A + 1B, phase B = 2A/B, phase C = 3A/B
Negative drive is ground.
Supply's AC from power transformer is 60 Vac.
Seems drive DC may be regulated down lower. Measured about 30V with supply just turned on.
and here is a crude diagram I made while doing some tracing in the controller...
Well, that's half of what I need. This has a circular connector on the other end like this.
https://www.ebay.com/itm/333940096912?m ... =1&mkcid=1
