DIY Turbopump Controller
Re: DIY Turbopump Controller
Post by John Futter »
Nicolas
It is hard to use linear optos to get volt and current sense across I make sure that there is series impedance then 5 volt TVS diodes across micro I/O pins
my comments were directed at some of the other posts where micro derived drive signals are use to drive the half bridge directly
a TMP 50 has about the same energy as a .22 LR cartridge where as a TMP150 is more like a .308 cartridge amount of stored energy
Nicolas Krause
Real name: Nicolas Krause
Post by Nicolas Krause »
Thanks for the clarification John, I've added the suggested circuit protection, now I just have to spec everything and layout the board! That's a nice way of thinking about energy as cartridge size, it's been awhile since I've been on a range but even though .22 LR is small I wouldn't want to be hit by either.
Michal Dvoracek
Real name: Michal Dvoracek
Post by Michal Dvoracek »
Hello,
I'm finally built up my turbo controller which is inspired by John's but it also contains speed measurement control.
I'm attaching some photos and video is here: https://youtu.be/OWJsfk7cNfQ
Regards,
Michal
Excellent
looks similar to mine. I could not post the digital controller as it was code written at work hence ip problems ..
But well done
Michal, a true love's labor and a grand win. I applaud both your and Nicolas' effort in electronics. I call it the hands on imperative or a "doer", doing. The epitome of the thrust of this site and of real amateur science is obtaining and retention of hard won skills that not only make life more full and rewarding, but in the making of a whole, capable person. You can be proud of your effort, you have earned the right to pride of accomplishment. Also laudable is the aid offered by John Futter and others in the quest.
I am sure that all here realize this is but a micro win in a demanded technology, (obtaining a scientific vacuum), along the road to the fusor and fusion quest here. One must never underestimate just how tough, costly, and demanding this amateur effort is to one's time and purse required for the acquisition of both knowledge and materials. It is not for kids. Big boy pants are needed if this task is taken on by any individual.
In the end, a win is laudable, but a win with useful experiment applied to the win is the ideal.
Note: the pep-rally is over. You can all get back to it....
Nicolas Krause
Very nice Michael! Would I be able to see your code and schematics? Always interested in seeing how problems I have to solve were solved!
Nicolas Krause
Just a quick update here. I've specced all the components for the Turbopump controller over the christmas break and now I'm getting in to the PCB layout. Lots of little details left to work out!
Real name: Dennis Brown
Post by Dennis P Brown »
Extremely impressive; your own design (yes, inspired by John's)? This is rather advanced level electronics driving a turbo - they are not simple motors. This is EE level work. That doesn't even cover the actual execution/build you've done.
Nicolas Krause
Thank you for the compliments Dennis, I still have to get it to work! The circuit is John's design, I've added a microcontroller to run the whole thing, but that's it.
Nicolas Krause
I've completed most of a first draft of the routing of the board. I can post the KiCAD files if anyone wants to take a look but some details still need work. This is the first time I've routed a 4-layer PCB and a board of this complexity. I'd appreciate any constructive criticism more experienced hands might have to offer.
1. Is there a rule of thumb for controlling trace size given the power running through them? I've made the traces going out to the motor much bigger, but I have 5V, 15V and then motor power traces all running on this thing, and I haven't changed either the 5V and 15V traces
2. For a 4-layer PCB I've made one of my planes the ground plane, and was planning on making the second some sort of power plane. I assume I should make it the power plane for the power traces supplying the motor, is this correct? Or should it be the 5V or 15V power plane?
3. Is it generally acceptable to put component labels inside the outline of a component? I'm having trouble getting all the labels to be visible.
4. How do I size vias for different trace sizes, so far I've just been using the default settings in KiCad, but that clearly won't work for my thickened high power traces
5. Any general constructive criticism about the layout of the board and the traces would be much appreciated!
Joe Gayo
Real name: Joe Gayo
Post by Joe Gayo »
Saturn tools for trace calculations ... https://saturnpcb.com/saturn-pcb-toolkit/
Think about where the high current loops are and make those as tight as possible.
The power plane can be split amongst multiple voltage rails.
There is an excellent video on PCB layout about how power actually travels in the dielectric space. https://www.youtube.com/watch?v=ySuUZEjARPY
Nicolas Krause
Thank you Joe, lots of good stuff to work through and learn! That PCB layout video is fantastic! I'm only a 1/4 through but so far it's been hugely enlightening.
Nicolas
that looks pretty good
ie no input lines to micro going anywhere near the 3 phase output driver
you will see that the motor peaks at about 1 amp during rampup ie a hundred odd watts and with no gas load settle to about 6-11 watts at full speed.
have fun
oh and if it turns the wrong way interchange any two of the 3 phase outputs
Nicolas Krause
Just a quick update on the progress of this controller. I've received the first draft of the PCB in the mail, and had built up nearly the complete board before discovering a couple of errors which means I'll have to do a second revision. They are as follows:
  • Double placed one footprint (see if you can find it!)
  • Polarized capacitors are packed too tightly, I cannot place all 5 with the current footprint layout
  • Holes for a diode bridge are incorrectly sized and the component does not fit
I've got a little cheap hot air setup here, so I figure I should be able to salvage all the bits without too much trouble.
Drat
comes to mind
I have put out a few custom boards and stupid mistakes are common and all part of the learning experience. The last two designs I had run were perfect. All the best in the rework. It is obvious you can save this first pass using good skills in work around assembly.
Nicolas Krause
Happy to report I've got a decent prototype version of the board going. The eagle-eyed amongst you will note this is rev. 3 and I did find a final 4th serious error that required a respin of the board (thank you cheap chinese PCBs!). I've nearly finished soldering up the whole thing as the photo below attests too. The next step is to write a little bit of firmware to run the whole thing. I'm using a raspberry pi Pico to control the device. They're absurdly cheap ($5) and pretty easy to populate on the board since they're castellated. I'm planning to write the firmware in Ada, I'm curious about a lot of the safety features of the language and this seems like a good project to use it on. I'm hoping to use a tool called SPARK that's available with Ada. It lets you prove certain properties about your program, providing certain guarantees about its behaviour.
Martin Fyhn
Real name: Martin Fyhn
Post by Martin Fyhn »
Peter Schmelcher wrote: Sat Jan 23, 2021 4:19 pm Nicolas these are internal pics of my NT10 controller circuit board before I repaired it but after cleaning with compressed air. It had previously been repaired by someone and was sold "as is". Unfortunately, I never found any schematics so I repaired it using these pics.
The NT10 controller spins up the turbo in discrete drive frequency steps with coasting between frequency increases. During the coasting moments the voltage produced by the motor windings are measured and used as a tachometer reading. As I recall the turbo needs to spin up within 2 minutes getting quickly through a 50Krpm mechanical rotor resonance.
Today my plan B repair would be a new variable frequency drive for a CNC router spindle ($130). The faster VFDs run up to 1000 Hz and I suspect that with a crystal change hack one could increase the upper frequency.
-Peter
Hello Peter,
Would you happen to have some photos that are closer, and/or more in focus, of these boards?
My NT12, freshly bought from ebay, is host to quite a few glass diodes, that has turned an unhealthy shade of brown (it wasn't me... I promise... It was like that when I got it *furiously polishes halo, and ends up getting electrostatically shocked*... No seriously - I tore it apart before trying to power it, as I suspected that there could be issues. I'm in Europe, and bought it from another European country, and found the voltage-selector set to 110V. Also found a filtercap near the supply, that was ripe for creating some fireworks (it's missing on your photo - in case it was missing when you got it, and you want one installed - it's a 4n7 Y2 safety capacitor)). I've desoldered one of the roasted diodes to check if it's functional, which it is, but I'd like to replace them regardless, but I can't identify the things. I can say that the one I tested shows no signs of being a Zener, and has a voltage drop of .55V, which leads me to think that it's a Schottky, but that's as far as I can get, and it's one in roughly 26 ':D
I'd also be veeeeeeery happy with the diagrams - and have sent a request for them on the google drive link, but as I'm an impatient bugger, I'd be exceptionally happy if someone could provide me with some juicy diagrams for my lovely little inverter! :D
Peter Schmelcher
Real name: Peter Schmelcher
Post by Peter Schmelcher »
I had a look for other pics and I did not find any.
Rex combined the schematics that Jerry posted and using them you can repair the controller.
Nicolas Krause
Slowly plugging away at the firmware for the controller. Have been learning Ada, and I have a development environment setup using gdb on linux. It's the first time I've worked with a command line interface for programming so it's been a neat educational experience. I've got the LCD communicating with the RaspberryPi Pico at the moment! Lot's left to do but always a fun step.
Nicolas
Those lines on the LCD look like swear words
LOL
Nicolas Krause
Just a quick update on this project since the last post I made is well over a year ago. At the time the project was just a bit beyond my capabilities as an engineer, work picked up and I didn't have the time to dedicate to it to make any real progress so it's mostly sat uncompleted on my desk. I've since come back to the project now with some improved engineering skills and step 1 is improving the schematic layout and writing up some documentation for myself. I'll likely re-route the board since I think I can do a better job now and then move back to implementing the firmware. Here's the updated schematic for the microcontroller section, but other parts are well underway!
Nicolas Krause
The schematics for the device have been successfully updated! They're quite a bit neater than they were previously, and much easier to read! A master schematic details the connections between 3 sub-schematics which helps greatly with organisation.
Fascinating work; so, what chip is that main processing chip in the second diagram? I have no experience with digital chips and that certainly looks very specific.
Nicolas Krause
It's a standard chip for controlling a 3-phase motor, the IR2130, the other chips essentially condition a clock signal so that the IR2130 turns the set of transistors to the right on and off in the correct sequence.
