IR / Visible ZnSe windows
Post by John Futter »
New ZnSe windows arrived from China.
I bought 10 of these from china custom made for approx $2000 75mm dia 5mm thick they are stunning
Real name: Dennis Brown
Re: IR / Visible ZnSe windows
Post by Dennis P Brown »
Obivously good for the infrared - so I assume that is their purpose? And why so many?
Planning on a gang of IR work? At 2 kilobucks, your are a serious guy.
I'm wanting to see an ion beam target with a FLIR camera and see how hot it is getting during implantation and also use it to look at a heated stage in a sputter system
and why so many
the sputter system will tend to coat the window so I got a few spares
Don't know the wavelength your using but if it is above 4 microns, a silicon wafer could be used to protect the ZnS window. Three inch diameter silicon wafers are rather cheap - or use to be; don't know if still avialable but might be worth looking in to if that wavelength is usable.
Wow, looked up the transmission of silicon wafers and it is closer to one micron! While its just 60% over 1.4 microns (high index) it certainly would be a cheap protection plate.
I once paid $100 for a giant (12" aperture) IR lens at a hamfest. It was undoubtedly some sort of military surplus IR lensing system. The lens weighed over 32 lbs! It had a totally opaque front element of pure elemental germanium. I kept it for about 3 years and sold it to a much more astute person at a hamfest for his first offer of $300. I now realize that there was about $8000 worth of germanium contained in that lens. Oh well....
I attach the pass band graph of a 5mm thick disk of pure germanium. Fantastic!
