Using diffusion pump oil in a mechanical pump
chucrut
Real name: Agustin Cruz
Post by chucrut » Tue Dec 31, 2019 5:29 pm
Hello,
I'm using a cheap oil for my mechanical pump and I have heavy outgassing and contamination from the pump.
In my country is difficult to get a decent quality oil for mechanical pump.
Do you think is a good idea to use diffusion pump oil in a mechanical pump?
Many thanks!
Agustin Cruz
Re: Using diffusion pump oil in a mechanical pump
Post by John Futter » Tue Dec 31, 2019 5:42 pm
CHUCRUT
How about following the rules
you have to use your real name as your persona on this site and your first post should have been the please introduce yourself subforum
This question shou;ld have been asked in the "New user Chat Area" subforum
Paul_Schatzkin
Real name: aka The Perfesser
Post by Paul_Schatzkin » Tue Dec 31, 2019 6:20 pm
<*sigh*>
--PS
Post by Richard Hull » Tue Dec 31, 2019 6:24 pm
Diffusion pump oil is about 30 times more expensive than good proper mechanical pump oil. Do you own a gallon of diffusion pump oil?
chucrut
Post by chucrut » Tue Dec 31, 2019 6:38 pm
Hi Richard,
I have diffusion pump oil here at hand. Is expensive, but is already here so I can try.
Do you think using this oil could help outgassing and contamination from mechanical pump?
Many thanks,
Agustin Cruz
Roberto Ferrari
Real name: Roberto Ferrari
Post by Roberto Ferrari » Tue Dec 31, 2019 7:45 pm
Agustin
Why do you start your long pursuit trying to use a wrong road?
Mechanical pump oil has several properties, not only oriented to get a good vacuum but also to protect the steel parts inside the pump.
Were are you based? Surely some provider of consumables for vacuum systems, as mass spectrometers, can sell you some quantity. Check someone in the University.
Sell or trade your diff oil!
chucrut
Post by chucrut » Wed Jan 01, 2020 2:02 am
Hi,
I will try to use a filter between the mechanical pump and diffusion pump to reduce oil contamination.
There are different types of filters for mechanical pumps. Copper wool, zeolite filter, fiberglass filter, etc.
I need to evaluate which one is easier to make here. DIY approach
Many thanks!
Agustin Cruz
