First ever Turbo experience
AngeloGomes
Real name: Angelo Gomes
Re: First ever Turbo experience
Post by AngeloGomes » Mon Dec 30, 2019 1:19 am
Here, we usually have the heater attached to the chamber, but not at the pump body.
About the venting... you have to wait for the turbo slow down the rotation and then admit air/gas in small amount. If I am not wrong, my pfeiffer performs the first vent operation at 1/3 of the max rotation and then two times more.
Our turbos in the labs: I think the oldest one has maybe 7 years and it is used ocasionally. Never had to go to pfeiffer or the oil changed. Maybe when we note a poor performance, we will think about it.
Post by Dennis P Brown » Mon Dec 30, 2019 1:36 pm
In your picture (your circled item), that appears to be the access port for the bearing oil wick. I added a few drops of oil to the wick at that location in my unit (it was dated 1988 and never serviced so I figured it needed new oil; hey, the unit, cable and controller ran all of $10), resealed the cap, and after a long bake out and pump down (the oil can have some water from the air if it has been openned previously and stored a long time - mine was) the pump ran great from there on.
The turbo pictured has a vent port (just above your circled plug; the port with the Kf-16 fitting) and that is where dry air can be installed/used to vent the pump after it is turned off. If venting at that location is not used, it is best to let the pump slow down completely before venting - even slowly. There is a danger to bend the blades in these older turbos if one lets in just a lttle too much air. Far better to err on the safe side and just let it stop on its own.
Post by Richard Hull » Mon Feb 10, 2020 4:53 am
As I prepare to mount my turbo that has remained fallow for 4 years. Purchased from a friend with a working system in 2016. I am ordering the pump oil ($50) which is a wick system oiler rather than a reservoir of liquid oil. I attach images. It seems weird the oil is distributed via a wicking system requiring the oil to rise up the shaft to the bearing via wiping it shaft with a wick!! Of course I do not know what a 90,000 rpm shaft does as traces of oil wipe off the wick. (Climbs the shaft against gravity?)
images show cutaway drawing with supposed conical shaft with wicking wiping the cone in two places. My pump in photo is a small round cylindrical shaft with a wick gasket rubbing at two points being keep wet via its feeding off the cup's oil laden wicking.
Don't mention the debris "bits" in the last photo, it has been removed
Bizarre.
Manual's view of what the wick cup should look like.
Cut away from user manual shows a bit different arrangement than mine.
Flash photo of wick in Cup and shaft
In the housing the wick washer is seen contacting the shaft in two places.
Post by ian_krase » Mon Feb 10, 2020 8:19 am
In at least some cases, the oil is wiped onto the shaft in the form of a thin film, and then centrifugal force drives the oil film outward and upward a shaft that's in the shape of a gently tapered inverted cone.
Post by Richard Hull » Tue Feb 11, 2020 7:37 am
I have the tiny $50 bottle of oil on order now. I just want to know that once I bolt the turbo to the table it is oiled with the proper oil as access to the oil port is forever not accessible once the system is finished. According to the manual it is good to go for 5000 hours!! This sucker better work!
My lab is a mess as all the old fusor IV bits laden all the benches ready for re-install of fusor IV if this doesn't go anywhere that pleases me. I move slow and will test all along the way for tight vacuum through out. Due to cold and the press of engagements, I'll be lucky to have this thing up and running by spring or early summer. The idea is to use what I have on hand here in the build or cobble up what I need.
Post by Richard Hull » Fri Apr 10, 2020 7:19 pm
Still mystified as to the need for the heater at the top of the pump. I have never even connected it. Likewise the external fan? I have run the turbo for up to 1 hour, (longest run in the now aborted fusor V effort), and felt the base of the turbo and it was at ambient??? Why the fan..? Is this for labs and processes where the system is left running 24-7? If so, I will never need the fan or the heater?
Still coming up on the wonderment of the turbo. I am very pleased with it, thus far. I had a moment of fear when the first arcs in fusor V turned the controller off automatically. but the reset button, (standby), always worked and restarted....Whew!!....
Andrew Seltzman
Real name: Andrew Seltzman
Post by Andrew Seltzman » Fri Apr 10, 2020 10:21 pm
The heater at the top is for baking out the pump when removing water vapor or contaminants if it will be used at UHV vacuum levels.
The fan keeps the motor cool when the heater is on, or when pumping very high gas loads, or gasses with high molecular mass such as argon.
Andrew Seltzman
www.rtftechnologies.org
Post by Richard Hull » Sat Apr 11, 2020 4:06 am
Thanks Andrew! Since I have no current aspirations for UHV, the heater is out and the fan will also not be used, due to the total isolation of the turbo in and out with valves. (Stays at low, "fore line" pressure, few microns)
When I shut down I shut the valve to the chamber, let the turbo wind down. (~10 minutes) This leaves the turbo and fore line at about 3 microns. I then valve off the turbo outlet to the fore line. then within seconds I turn off the mechanical pump and slam off pump's exhaust line with a ball valve, then let the pump up to air and immediately reseal the fore line. Thus, the mechanical pump can't "breathe" in or out. (The exhaust line goes out the back of the building)
When I start up, as I hit the mechanical pump switch, I simultaneously open the exhaust line ball valve. I typically hit 10 microns within 20 seconds on the fore line. I then open the outlet valve of the turbo and the fore line pressure might drop or rise by 2 or 3 microns I immediately open the chamber valve and the pressure on the fore line might rise on the TC gauge to 40 microns but within seconds is back down to 10 microns, due to the small cross volume. I start the turbo immediately and within 60-80 second from starting the mechanical pump, the chamber is sub micron (0.0500 micron on the .1 torr baratron) with the fore line TC gauge zero'd out. In the remaining 3 minutes of spin up the baratron drops the chamber to a rather stable 0.002 micron.
Dan Knapp
Real name: Dan Knapp
Post by Dan Knapp » Sat Apr 11, 2020 11:44 am
Turbo controllers often include signal lines for rotational speed readout (commonly 0-10 VDC) as well as a switchable line for reduced speed or “soft start.” I find it useful to be able to switch to reduced speed and read out the rotational speed (yet another use for the red HF freebie meters).
Post by Jerry Biehler » Sat Apr 11, 2020 9:48 pm
Use the fan, it is still needed without the heater. You can fry the bearings otherwise.
