Can I make my own ConFlat flanges?
- Real name: Matthew Lallinger
Re: Can I make my own ConFlat flanges?
Ameen,
Are you planning to build a fusion reactor or just a vacuum chamber for various experiments? If so, I wouldn't think you would need an 8 inch CF flange unless you already have a chamber you are going to use and need a blank to close one of the ports, or if you are making a massive vacuum chamber. For fusion you could use a chamber with only 2.75" CF flanges. In that case the flanges could be made on most manual and CNC lathes with proper tooling, or bought for even cheaper from somewhere such as Ebay or LDS vacuum. LDS vacuum has 8 inch CF blank flanges for $120 USD, it would be tough to manufacture a flange of this size even cheeper.
Also, there is no need to quote my post if you reply.
-Matthew
-Matthew
- Real name: Ameen Aydan
Hello,
I was planning to make my fusion reactor 6” in diameter. I just thought I could use a cnc machine from a college that would be willing to help due to their precise technique, and if that doesn’t work, my school has a 2 axis cnc machine that works on old software. And like I said, I would polish this to an extreme to prevent any leaks. As you can see, the price of using a cnc machine does not concern me, but the cost for a $120 flange does. I’m only asking if it is possible to reach fusion atmosphere with a homemade flange.
Ameen
Ameen
- Real name: Jackson Oswalt
Yes, it's possible to reach pressures low enough for fusion with a homemade flange. The real question is whether or not YOU Are capable of making a good enough flange. Unless you have experience with precision machining your chances of creating a usable flange are very low. You would be far better off purchasing these flanges. In fact, I have two that are brand new from LDS vacuum if you'd like to purchase them. However, reality is that they will cost more than $120. If the price of the flanges scares you, then you may want to revisit this project once you saved up some more money. Building a fusor is costly.
It's not needed to have conflat flanges for fusion. If you can do CNC machinist, an O ring groove is more than good enough.
- Real name: Tom McCarthy
It is possible to machine CF flange on a CNC machine, but it really depends on the machine. I am assuming you mean a CNC milling machine. In that case it will ultimately depend on the specific machine. Is it rigged enough, big enough, etc.? I doubt a college workshop would have the proper machine and the necessary tooling to create the knife edge.
CF flanges are made to work at the ultra high vacuum (down to 1X10^-13 torr). A CF flange is not at all necessary for fusion pressures. Really, any O ring sealed flange, such as a KF or ISO, will work great as long as the proper material is used (Viton, nitrile, etc.). You could make a CF flange, but not use a knife edge, instead you could use an O ring groove. Regardless, stainless is a very difficult material to machine, and if you decide to go with a CF flange, it would be far easier to purchase one.
Are planning to use the 8 inch CF flanges for a spherical chamber?
-Matthew
-Matthew
The college that i'm asking has very heavy and precise milling machines (yes, CNC milling machines), that being said, I would imagine that it is possible to create a knife edge. Just thinking of it, MDC or Kurt J. Lesker probably have the exact same CNC machines in terms of specs. The CNC machines they used in accuvac, in this video https://www.youtube.com/watch?v=vGNRapSjGVU, are also the same as the colleges from what I have seen. So maybe it is possible, but I would need to know the accuracy of the knife edge to what degree in order to integrate it into the making of the ConFlat flanges. If that doesn't work, I would be happy to look at the design of an O-ring ConFlat flange. And yes, my plans are to create a spherical chamber with a diameter of 6", and if my plans to make a ConFlat flange go well, maybe even 8".\
Ameen
Ameen
ameen
will you pplease stop copying in what others have said in your replies
it wastes server space and makes things hard to read and as such is frowned upon on this site
i apologize, i am new so thank you for giving me these tips, it is quite helpful.
I went back and edited out the quotes and am sensitive to the needless quoting by many noobs and will continue to delete and edit out long needless quotes.
As always, we, here, are smart enough to follow a thread from beginning to end without repeat-re-quotes within a single original posting.
