cheap solenoid valve
JoseRey
Real name: José Rey López
Post by JoseRey » Wed Jan 10, 2018 11:25 am
Has anyone tried this cheap solenoid valves
https://www.amazon.com/Brass-Solenoid-N ... B01E0NRW30
to hold vacuum for some minutes
i don't expect much from them, but they may be worth a try
Thanks
Re: cheap solenoid valve
Post by ian_krase » Wed Jan 10, 2018 8:56 pm
Almost certainly requires high pressure in one direction to make the valve open. Not really useful for vacuum.
Post by Jerry Biehler » Thu Jan 11, 2018 4:21 am
It does not look pilot actuated. It might work. There are electric solenoid valves with kf fittings, I have one in KF16.
JoseRey
Post by JoseRey » Thu Jan 11, 2018 2:20 pm
I know, but they are much more expensive
Fusion
Post by Fusion » Tue Feb 13, 2018 9:42 am
This one (10$) said works in vacuum:
https://www.amazon.com/4inch-Normally-C ... cuum+valve
Advises works in zero differential pressure.
This also as advises in the sticker:
https://www.amazon.com/Electric-Plastic ... m+solenoid
