Chinese pump first run report.
Pascal Mueller
Real name: Pascal Mueller
Re: Chinese pump first run report.
Post by Pascal Mueller » Sun Dec 23, 2018 12:45 pm
@Dennis: You said that "generally ethyl alcohol - absolute is best", what do you mean by absolut? Do you mean the brand? Like absolute wodka? If so: Why not go to your local pharmacy and just buy pure ethanol? At least in my country you can get 98% ethanol over the counter. (You could even drink it - there is also the one that you can't drink.) Just tell them you need it for tinctures.
William Pete
Real name: William Pete
Post by William Pete » Sat Feb 23, 2019 10:29 pm
That's a good price on the pump, I believe I saw this one before combing through ebay and thought that it may not do the job as some of the used Edwards pumps were present in a lot of other jerry rigged builds like what I am going for.
I'm definitely going to keep this one in mind as I move forth.
