Buy head for Edwards controller or...
Sven Andersson
Real name: Sven Andersson
Post by Sven Andersson »
A research engineer at the Ångström lab in Uppsala gave me some stuff that may or may not be working. I want to measure pressure in the Fusor range or perhaps a little bit higher (1-100 Pa). Should I buy a head for the Edwards controller (left) or a controller for the Granville-Phillips head (right)? Both can be found on eBay.
What kind of head can I use with the Edwards controller? APG-M it says. Can I use APG-MP too?
Sven Andersson
Re: Buy head for Edwards controller or...
Post by Jerry Biehler »
Either will be fine. I dont think the MP heads are compatible but you could call up edwards and ask for sure. The system I built for work uses the APG-M heads.
The convectron ones work good too, just make sure you put the gage tube in the right position.
