FAQ: Complete fusor diagram
Post by Richard Hull » Tue Mar 02, 2004 3:37 pm
Attached is a diagram of the complete fusor hookup for a deuteron fusing fusor. Demo fusors can do away with the neutron counter and all deuterium gas handling sections.
The TV camera monitoring system is optional.
The wiring details are covered in the High voltage and power forum over numerous postings and FAQs there.
This image has been in the "newbie" section at the introduction portal, but few newbies have bothered to consult it and constantly demand this info. I have posted it in the High voltage and power fourm as well.
Clayman
Re: FAQ: Complete fusor diagram
Post by Clayman » Wed Apr 06, 2005 8:36 pm
hey, cool i've looked at the newbie area, but was still unsure on how to make a reactor. thx
Logan~
Brian McDermott
Post by Brian McDermott » Wed Apr 06, 2005 8:47 pm
Unfortunately, that is not a question that one can answer in a few words. Look around on the forums a bit at old messages, and at some of the websites listed in the newbie section. The forums have a search function, which can be found at the top of this page.
Also, introduce yourself in the "Introduce Yourself" forum and tell us a bit about yourself and what you want to do. We'll be happy to answer any questions you have.
Post by Richard Hull » Wed Apr 06, 2005 8:51 pm
A picture is still worth a thousand words.
Gianluca Sarti
Real name: Gianluca Sarti
Post by Gianluca Sarti » Mon Jun 17, 2019 7:59 pm
hey i'm trying to build a fusor and i have a question.
what does the "trap" in your diagram leading to the vacum pump do and why is it important
Post by Richard Hull » Tue Jun 18, 2019 7:36 am
Most all fusioneers never use a "fore-line trap". It is part of any real professional system and is included as an "ideal" item to have in a vacuum system.
The trap is there to keep mechanical pump oil vapor out of the secondary pump. The secondary pump is either a diffusion pump or a turbo pump.
I am attaching a fusor vacuum system image of the type most often used today. Some people do not use a diffusion pump and replace it with a more modern turbo-pump. You must have one or the other in addition to the mechanical pump.
Very basic diagram of modern fusor vacuum system
Gianluca Sarti
Post by Gianluca Sarti » Tue Jun 18, 2019 11:32 am
Big thanks to you Richard Hull
