Our progress
David Lloyd-George
Real name: david lloyd-george
Our progress
Post by David Lloyd-George » Sun Dec 30, 2018 10:29 pm
we have made some progress with our fusor efforts. We bought a vacuum pump from eBay. the model is a a Trivac D8A. We inspected it using the very helpful guide on this forum and put new vacuum oil in. The oil used is VacOil 19 grade and we filled and drained the pump with this oil a few times to clean it out fully. The pump seems to be working well however we do not have a working vacuum gauge at the moment.
We had bought a 6in CF flange T-fitting a while back but decided to go with a 2.75CF flange 5 port chamber instead because of the price and availability of similar fittings. We constructed our chamber with a 2.75CF butterfly valve and an air cooled diffusion pump which we haven't used yet but have taken apart and inspected. The heater element has an electrode that is missing but we were still able to test it and it seems to function properly. We have done several pump downs with our roughing pump however, we have been unable measure due to the lack of a vacuum gauge.
We have ordered a vacuum gauge and a HV feedthrough and are expecting those to arrive soon. We hope to be able to achieve a basic plasma within a few weeks.
Thank you,
David Lloyd-George and Beauregard Pearl
Pablo Llaguno
Real name: Pablo Llaguno
Re: Our progress
Post by Pablo Llaguno » Sun Dec 30, 2018 11:14 pm
Looks good! If I may ask, where did you get that nice air cooled diff pump? Those are hard to get nowadays :)
Also, for the vacuum gauge I highly recommend the MKS 901p transducer, I have a post (and also others) on how to set it up very easily with an Arduino board and LCD/OLED display, very cool little gauge that works very well!
Re: Our progress
Post by Richard Hull » Mon Dec 31, 2018 3:34 am
That little diff pump is as cute as a button. It should serve well in the smaller chamber you now plan to use.
David Lloyd-George
Re: Our progress
Post by David Lloyd-George » Fri Mar 15, 2019 7:14 pm
We have made some progress in our efforts. After buying a Teledyne Hastings DV-6M gauge and controller, we tested out our pump. We connected the gauge directly to the inlet of the pump and after 20min of pumping, we had hit 15mTorr. Since we have two TC gauges, we corroborated our results with the second one and got approximately the same values after 20min. We then tested the vacuum chamber however we got significant leaks in the inlet of the diffusion pump. We added some teflon tape onto the inlet however that didn't stop the leaking by that much.
(vacuum gauge readout at ~12mTorr)
(our setup for pump testing)
In regards to the other parts for the fusor, we have made some progress as well. We now have a better X-ray transformer capable of outputting 100kv @ 10ma (we still have to do further testing though) and we have bought a 30kv high voltage feedthrough along with ceramic tubing to use as an insulator.
We have bought a 60KΩ 225W wire wound resistor that we will use as our ballast resistor. 50kv high voltage wiring and 30kv 100ma diodes were purchased as well.
(X-ray transformer)
(feedthrough with ceramic tubing on stalk)
Any comments or questions about anything would be much appreciated.
DLG & BP
Re: Our progress
Post by Richard Hull » Sun Mar 17, 2019 10:07 am
It looks as if your materials on hand are just fine. Good luck.
