Cutting edge GM counter (1953)
As some here will know, I collect and restore old Geiger counters from the U-boom era (1949-1960).
I have just restored a very rare, seldom seen, Hoffman "Count master" Geiger counter/rate meter/scaler. It has sat around for 10 years.
Amazingly compact and light weight for its time, it includes an unheard of all electronic digital counter, (scaler), and mechanical timer built in.
It employs only three vacuum tubes! None of the tubes are in charge of, or involved with, the digital counter!
The four decade counter uses only NE-2 lamps, capacitors and resistors. Normally such decades of the period that used NE-2s as indicators in stacked decades demanded 4 flip flops made up of 8 vacuum tubes per decade.
GE was the prime manufacturer of the series of NE lamps and produced a thick manual on their use. It seems that due to their natural hysteresis (on-off voltage characteristics), a form of ring counter can be assembled using only 10 small NE-2 lamps per decade as both the active and indicating components.
I was stunned at this rather ingenious work-around for the period. In reading the GE manual one notes that the NE-2B lamps are used which are more stable, and even then, for best results, they should be selected by hand from a batch to match their characteristics. Hoffman took the time and effort back then.
My restoration consisted of replacing two old foil electrolytics with modern 1/10th size replacements and the HV wax filled 1600v filter capacitor.
I also replaced what was supposed to be (2) 75 volt batteries, with one of my tiny 6 volt to 120-160 volt adjustable supplies for the vacuum tube plate power. I made a few adjustments to the metering pots and it worked perfectly.
For those old farts like me who remember the HV carbon-zinc pile batteries, I never heard of or have ever seen a 75 volt battery. I clearly remember the voltages of all such batteries that were common to the period. They were 15 volt, 22.5volt, 30 volt, 45 volt, 67.5 volt and 90 volt. The highest voltage Eveready made was 540 volts. This 540 volt battery was produced exclusively for the early "Strobenar" photographic Xenon portable flash units. Any "old boy" ever see or handle a 75 volt battery?
I attach an image of the finished counter. click on it to enlarge.
Re: Cutting edge GM counter (1953)
Post by Rex Allers »
Great work on bringing this primo device for the time back to life. Nice job.
The description of the NE decade counter design is amazing. I've never heard of such a thing.
I recently got an ebay x-ray monitor, circa 1975 design. It also uses a high voltage battery (300v). Not for tubes but for the detector. There was a very dead battery in it. Swollen from years of age. Quite a battle to get it out without damaging anything I was prying against.
Here's a pic of the cardboard case from the battery that I saved for reference.
Like you I replaced the 300V battery with a small switching supply for testing. I could fit something into the battery chamber, but...
The device seems to be doing some odd things and I have no schematics. For me, this project is now bumped far down my list. Too many unknowns to try to hack it.
Post by Rich Feldman »
Very cool.
I used an instrument with the same kind of 10-lamps-in-column decade counters, in summer of 1974. It had been in continuous service since new. Measured elapsed time, in milliseconds, for profiling soil depth by seismic refraction.
http://www.geowavesolutions.com/refraction.html
Rex,
Thank you for the battery exterior image. That type of Ever Ready battery packaging design was their last gasp at the major high voltage "pile" batteries, using carbon-zinc battery technology. Your Battery is another rare bird. By the early 80's, Ever Ready killed their use of their most famous logo...The black cat leaping through the numeral 9 as their "nine lives" image so familiar on all of their batteries for a half century.
I have been trying to track down data on when Ever Ready ceased all such battery construction. Wiki notes that the Ever Ready of old is no longer. Union carbide sold off their Ever Ready battery division to Ralston Purina in 1986. I truly feel that this was the end of Every Ready pile batteries. The last 67.5V battery I bought was in the early 1990s from Batteries Plus, at that time they did have access to the 450 volt Ever Ready battery. I went back in the mid 1990's and they said Ever Ready no long produced any High voltage batteries over 30 volts and that those were in jeopardy.
Since 1986 the battery division has been resold a couple of times and is currently listed as "Energizer Holdings" and over 80% of all Ever Ready batteries are now made in China. The one single Ever Ready production facility in the U.S. making batteries is in North Carolina.
All of this was to be expected over time. Almost no portable devices today demand the use of an internal voltage exceeding 9 volts. Real power for such portable devices are limited to NiMH and Lithium batteries. If high voltages are needed in portable situations, modern switcher boost technology is used powered by high capacity low voltage cells.
Toys and cheap electronic junk items sold worldwide, still use carbon-zinc batteries. I was stunned to learn that all Ever Ready "Energizer" batteries are still carbon-zinc made in China. These are in a black wrapper. Only those Energizer batteries with the alkaline or lithium chemistry use those words on the label which is usually bright aluminum labeled. The Bunny, never imaged on the battery, has replaced the Cat.
Nuclear portable instrumentation was produced with vacuum tubes until the late 1960's. Many government and civil defense agencies had thousands of these instruments on hand and this demanded and supported the continued production via government contract of these pile batteries into the late 1980's. Some transistorized gear made as early as the late 50's still needed the HV pile batteries for the GM Geiger tube's high voltage circuit.
Total solid state independence of pile batteries really took off in the late 60's with tiny step-up transformers to obtain high voltages needed. The old tube gear used a vacuum tube based inductive boost oscillator to push the 90-115 volts pile battery up to 1,000 volts for the GM tube.
I include some images for the youngsters of what "real batteries" used to look like.
Good images of the two most popular pile batteries, 45v and 67.5v and then one of a whole gaggle o' high voltage batteries up to 90 volts.
Pile batteries.jpg (21.61 KiB) Viewed 7347 times
Richard, Great history on the HV batteries.
Another unusual thing about the 300V battery is its connection terminals.
Here's a pic of the connection assembly from inside the battery.
The battery had red and black sockets that plugged onto standard sized banana plugs in the device. The only change from when it was in the battery is that I soldered the red & black wires on it to use for a replacement supply.
The device is a Radcal mdh 1015 Radiation Monitor. From some searching, the design was around 1975 but I just looked at the device and there is marker pen writing that says, "New 4-27-88". There is a label that says it passed testing in 2008, and surprisingly, there is also a label that says the 300V battery was replaced 9/18/06. I looked at the battery cardboard and the bottom end has printing: 1205.
So it seems that battery was still being made by EveReady at least in the end of 2005. More recent than I would have expected.
The dates on the device are a bit newer than I realized too. Maybe it can be got working. One of these days.
Bob Reite
Real name: Bob Reite
Post by Bob Reite »
I remember building a "two tube radio kit" in Cub Scouts that used a 90 volt "B" battery (plate supply) A D cells for the "A" battery. (filament supply)
it had a 1U4 grid leak detector and a 3Q4 (or was it a 3V4? Same tube, different pinouts) power amplifier that could actually drive a 4 inch speaker.
1 volt and 3 volt tubes were the tubes used in all pre-transistor portable radios taken to the beach and out door dance parties from the late 40's until the very late 50's and early sixties when affordable transistor radios replaced them. All early military GM counters used these tubes as early as 1945.
1 volt filament tubes were nothing new. They go back to the 20's into the early 40's, but all the early ones had the rather large, odd 4, 5, 6, 7 pin bases. Ultimately, all major receiving tubes in the late thirties and during WWII standardized on the large, octal base. Needless to say, the early portables of the 1920's-1930's were not very portable, but were luggable. With the advent of the 9 and 7 pin "minature" tubes during WWII, portable battery powered gear became smaller and lighter.
I looked at my last buy on the 67.5 volt, and as you can see in the pix, I bought this in 2006. So, they were still making these in 2006. I do know when I went back to Batteries Plus a year or so later, they said all high voltage pile batteries were no longer available. Note: This battery is still functional in an old precision GM counter. Admittedly it is rarely used beyond making sure it works a couple of times per year. Still, the shelf life is amazing.
Now I just don't know the exact date of the end of pile batteries by Ever Ready.
At risk of taking this a bit farther than it needs to go...
I'm now puzzled by how one should interpret the Eveready date codes.
The battery I had has a code of 1205 and other info makes 05 = 2005 seem reasonable, so I assumed the first two of 12 meant the code was for
1205 = Dec 2005
Now you provide us with an example of 9706 and again your purchase info seems to indicate the 06 = 2006 is ok. But the 97?
In a year, only 12 months or 52 weeks but too many days for two digits. From above examples I assume we can trust the last two as year but the first two have me stumped.
It'll be OK with me if we never know the encoding, but I thought I'd share my puzzlement.
I have lodged the question of when Pile battery production ceased with Eveready on their website. They note that it may take 3 days to respond.
If they do, I will add this info to this thread.
I did find an image of the rare #497 - 510 volt photoflash battery. It was not a very big or heavy battery as it was worn in an over the shoulder leather bag with a cord to the pentax strobinar flash attached to the camera. Note: This one is from the 60's or 70's as it still pictures the cat leaping through the 9...Note: The bold claim about bouncing back after use on the label (See bottom of image)
Of great importance is there claim on the label in this image about leaping back to power after use. (nine lives) It is true!! I found this out on my discharge tests in my GM counters I make for sale. My counters use a common 9v transistor radio battery for power. Unfortunately with the bright blue, back lit, 4X20, LCD display, the drain is ~80ma. This far exceeds the recommended load, even for an alkaline battery. I ran 5 repeat testings of the two for a dollar, 9v carbon-zinc, Sunbeam, (chicom), Dollar Tree batteries. My counters work on 5 volts and I use a low drop out regulator on the circuit board. In this manner, I can drain any 9 volt battery down to 5.6 volts and the counter will keep working.
The carbon-zinc, Dollar Tree batteries for continuous on-time lasted 13 minutes before crapping out on the first run. I ran the second battery for 14 minutes before it was below 5.6 volts and died. The next day, I went on testing alkaline and NiMh 9 volt batteries. On the third day, I grabbed one of the dead Dollar Tree carbon zincs and ran the test over again. To my amazement the starting voltage was 9.2 volts and the battery again ran for 14 minutes! The second battery ran for 14 minutes again as well. Given a day off, they fully recovered! Sweet...
I mused over this welcome, but puzzling outcome. All 9v carbon zincs are pile batteries. Remembering my detailed knowledge of these batteries chemistry, I remembered the polarization of carbon zinc cells about the carbon anode, and the chemical solution to combat this cell resistance increasing phenomena. With the heavy loading forced on the small battery, the de-polarizing chemical near the anode was simply over powered and could not keep up with the load demand. The battery internal resistance increased killing its output to the load. With a rest,the ever mobile, diffusing, depolarizer did its job at leisure and the cell was like new again. This action allowed the cheapo batteries to restore about 6 times before the voltage and run times were reduced to under 10 minutes. The "nine lives" wasn't far off the mark, just due to the nature of carbon-zinc chemistry!
For Rex and others amusement and I think amazement, I have included the URL to the PDF of the entire GE neon lamp application manual. page 62 gives information on the ring counter. I, long ago, printed and GBC bound the entire manual. Those guys of the 50's and 60's made these little lamps do a lot of stuff far beyond just being indicators!
https://w5jgv.com/downloads/General%20E ... dition.pdf
Regarding the Eveready inquiry...... Idiots!..... I got a response from the complaint department which was, apparently, tasked to answer my question. "we don't no nutin' about no old battreees"..... "if you would like us to push this up to the headquarters division, please let us know in a reply to this message"..."note if you do not reply within 2 days your query number xxxxxxx will be closed."
I replied to push it up the chain....The beat, like the bunny, keeps on going and going and going....While the cat remains dead.
Wow. I, at first, thought you were linking the GM counter manual.
All about neon lamps, 1966. Really cool, man. More than 100 pages. I'll have to digest it slowly.
One comment. I wish the guy that wrote the (pencil?) notes in it had better handwriting. Looks like good additions.
As for the Eveready reply. I don't want to get into, "Hey, you kids, get off my grass", mode, so I'll just let it pass.
My first and only 90 volt battery was pretty old stock in about 1970.
Dad had taken me to J & H Outlet store in San Carlos. There we found all the parts
for a neon glow lamp blinker (relaxation oscillator) circuit in an already-old magazine or book.
Don't know if I've ever gotten an electric shock from a battery after that one.
Be glad you didn't stumble onto the 510 volt battery. It could supply a few milliamps! I laid eyes on a 510v batt in Batteries Plus. They have recessed, flat, silver-plated pad contacts. (see previous photo) When new, they are covered with a plastic insulating film. When placed into service, the battery door has a spring that forces the top of the battery into spike contacts in the photo flash battery holder. These pierced the film to make contact.
I have been shocked by the naked button contacts on the 90 volt jobs when a young boy...WOW!...DC is nasty. If you are at all sweaty the 67.5 volt battery will ring the old bell, too.
Finally!! It took a few weeks, but apparently Eveready had someone go down to the sub-basement nether regions to talk to the "old retainer" sitting at the slant top desk with his green head visor on. Eveready stopped production of a all stack cell carbon-zinc high voltage batteries in 2011. Now you know and can talk with authority on the demise of those old portable vacuum tube application batteries of yesteryear.
Real name: Mark Rowley
Post by Mark Rowley »
I’m a bit late on this thread but wanted to say that restoration of 1950’s geiger and scintillation detectors has been a years long hobby as well. Detectrons, PRI’s, RCA, Babbel, and Mt Sopris are just a few of my favorite detectors. Without disrupting the originality of the unit, i make it a point to assemble replacement power supplies to negate the use of unobtanium B batteries or the 22.5v versions.
The photo is just a small sampling of my PRI 111B stock. The YouTube link is a refurbished 1954 PRI 111 Scintillator which uses 2 D cells and four 9v’s to operate.
https://youtu.be/D4Nydiq10aE
Wow! Bill Kolb and I love those old precision "ray gun" scintillators!! Nice work. All of my restorations also use home built B battery eliminators. I have done several of the precision chrome plated GM restorations as well as some Nuclear Chicago GM counters and ion guns (ala cutie pie)
Providing you have yet to see it, you may like this. It’s a 12 minute “commercial” made by PRI in 1955. It primarily focuses on the benefits of the “Ray Gun” Scintillator (aka 111/111B) with no shortage of action shots.
https://youtu.be/fCdB1Wdc5VI
Thanks for the URL. I have passed it on to Bill Kolb and others. A great little short promo film. I noticed three things.
1. I noticed the little tiny Crosley auto in the film. Rare and worth a fortune today.
2. The voice of the narrator was that of the man who introduced and gave demos at the beginning of every episode of Science Fiction theater 1955-57 TV show that I watched religiously as a young man.
3. Did you see the credits at the end of the film? Mc Gowan was the producer/director. Ever read the book “Uranium Fever or No Talk under a Million” by Raymond and Sam Taylor? Mc Gowan is the director from Warner Brothers who Raymond and Sam Taylor worked with through the bulk of the book to produce a feature length film about the U boom, which was a nightmare. Mc Gowan is portrayed as a nail biting, paranoid nervous Nellie who was freaking out constantly during the filming. The Montgomery fellow in the credits was also part of the film crew in the book.
Bob Reite
Post by Bob Reite »
I remember getting a PRI 111 in an Olson Electronics $5.00 "surprise box". Alas it was missing the PMT and the attached crystal, the most expensive parts. I don't recall what became of it, probably traded it or sold it at a hamfest ages ago.
Around 1998 / 1999 Allyn Goshy and a couple others obtained quite a few 111/111B units and refurbished them with battery eliminator supplies (Goshy being the most famous imo). Due to the scarcity of geiger counters in the public market coupled with the Y2K fear, I saw these being sold for $500-$1000 a piece. $500 may have been the price to send in an unrefurbished version for upgrading. Sales appeared to taper off around 2002 or 2003. Today, unrefurbished units tend to sell between $50 and $150.
I have several of the Goshy supplies and I have to complement him on his work. Hand wound transformers and personally designed circuitry. Something of a rarity these days.
The 111's are generally sought after by Star Trek prop collectors as they were featured in one or two episodes. Sadly though, when the prop folks get them they are quicky gutted like a trout and spray painted flat Krylon silver.
Like Bob, I obtained a gutted "Tower" brand work alike111 (Sears and Roebuck's house brand made by El Tronics). El Tronics made a near carbon copy of the precision 111 scintillator. Sears got into all the fads and created house rebranding of normal products. They sold Henry J autos for a few years as their "Allstate Six" Those who know Sears products will remember that all their automotive products, batteries, tires, etc., are all "Allstate" house brands.
I took just the ray gun and tossed the battery pack and electronics and turned it into a GM counter over 25 years ago. I kept the meter and on-off, range switches and placed a 5979 GM tube in the snout, boring a 1" hole in the end to expose the mica window. It still functions and uses a small 9 volt transistor battery and a little 1" speaker. All circuitry is stuffed into the large round rear chamber of the gun. I find it difficult to believe the battery I put in the counter still working after 7 years in the gun as I just took these two images after pulling it out of storage.
The ElTronics PR31! I just restored one a year ago August. Those are fun to work on. Unlike the subminiature laden PRI’s, the PR31 uses a 1U4 and three 1U5’s. Performance wise, the PRI seem to be better and more stable. On the bench are also three Detectron DS234 Scintillator guns. I’ve yet to restore them but I may do so next year. If they perform anything like the lunchbox DS-222 or DS-277 scints, the PRI’s may have a contender.
A Facebook friend builds small modules which incorporate a HV driver and a pulse amplifier. It’s even compatible with an MCA and easily powered by 5v. I’ve been planning on gutting one of the more distressed 111B’s and modernizing it with one of these modules. Who knows when I’ll get to doing it, but it’d be a fun project similar to yours.
Roberto Ferrari
Real name: Roberto Ferrari
Post by Roberto Ferrari »
In my small collection, I have a Isoto, built in Argentina during the 70's. Copy of a French design.
Unfortunately I have no schematics to attempt to rebuild it.
Hi Roberto,
I have two of the French SPP2 versions and have noticed they are more or less modern versions of the PRI 111 detectors except that they have the audio squealer function (similar to how a classic metal detector sounds when getting close to a metallic object). Based upon your picture, the main box has some differences which makes me think the circuity may be different than the SPP2.
Hopefully the design of yours follows the modular arrangement found inside the French version. It makes for very easy disassembly as well as easier tech work. Fixing any malfunctions should be fairly straightforward.
Somewhere in my files I have the schematic for the SPP2. Let me know if you think it'd help. I can forward you a copy.
My repairs/rebuilds do not have to save the patient's internals or respect the original purity of circuitry contained within. If the patient is more dead than alive, I tend to gut the circuitry and update all circuitry to a more modern standard. What is important is to at least attempt to maintain the original outward appearance and calibration. This is easily accomplished in 99% of what I do. I make every attempt to save the vacuum tube identity of the device. But, sometime the old circuitry just will not respond especially if the circuitry is too tightly packed in or the 25-50 henry boost HV choke is shot. Most of the time when this key component is bad, it is due to battery juices and vapors getting in or settling on the 2000 turns of #56 or #68 AWG windings in the choke and corroding many opens in the turns. 90 percent of the GM and scintillator issues are HV related and or B battery elimination issues. Filaments can remain lit as always, ("D" cells). I tend to check the old tube circuitry by putting the usual 120 volts on the HV oscillator by just clipping in a variable 0-150 volt DC supply. If the counter comes to life, it is just a matter of installing a good, tiny, home made B battery eliminator board and a new lower voltage battery to power this add on. Usually there is a ton of room ready made in the old hollow for the two B batteries.
From my standpoint I desire a look-alike, work-alike restoration via the easiest and most reliable path. By gutting 100% of the tube circuitry and replacing it with the latest circuitry, I find you have enough room in the typical old counter to build an entire rad lab inside. Each job is unique for me.
It is rare for me to be approached by someone wishing a full flawless restoration with no alterations in an old counter. It does happen, but they need to check their pacemaker as it will not be cheap. One recent restoration had me creating a small bass wood frame with beveled corners and pasting on the old original battery printed labels with a small battery and miniature boost board inserted within which looks just like the original eveready or burgess B battery which snaps into the original battery clips. Got $450.00 for that one. The counter needed no work other than cosmetics. The customer knew what he wanted and had the cash to pay for it.
I have very tiny battery eliminators that I have designed, but I attach, here, an image of my combo install board normally inserted in many tube systems. Not only does it eliminate the B battery, it also supplies GM tube voltages variable from 400 volts to about 900 volts, as well as outputs a positive or negative prefect square wave pulse from the tube of 50us width.
Return to “Images du Jour”
