Activation of Uranium by using a Fusor?
Administration forums. These are mostly old posts that are no longer relevant. It also contains numerous files that were not located in the proper forums by the original authors. As such, it is a smattering of just about everything. This is a Read Only section. No new posts or replies are permitted.
Locked
Brian Daker
Real name: Brian Daker
Post by Brian Daker » Sun Sep 13, 2015 9:24 pm
I dont know where to post that.. so i will post it here
i thought i have posted that already anywhere but i cant find it so thats my new topic
Unfortunately my english skills are not that good.. so forgive me if i do any mistakes
Currently i am planning to build up a fusor because i want to try out several things with it.
At the moment i got a x-ray transformer for 60kV but i dont know if its enough.
So now to my question..
i have extracted some Yellowcake from Uranium Ore (around 5grams) and i want to put it into the fusor chamber
if everything works well.. and i get neutron emissions.. would it be possible to activate the Uranium 238 isotopes and get Plutonium 239? or will there be a fission again of the Plutonium 239?
i thought it might work in this 2 ways
Please help me about my theory
thanks
Re: Activation of Uranium by using a Fusor?
Post by Richard Hull » Mon Sep 14, 2015 5:25 am
The deuterons do not have the energy in the fusor in the first line formula.
The neutrons are far too few in a fusor and the cross section for U at their energy is too low. What fast neutrons interact with the U will cause it to fission. No one has detected this yet.
The fusor is just not capable of any of these reactions that would be possible or even detectable at the amateur level. Your can give this idea up as it will go no place.
Andrew Robinson
Real name: Andrew Robinson
Post by Andrew Robinson » Mon Sep 14, 2015 6:13 am
Not to mention the negative attention of these types of topics in this forum.
Locked
