PEM fuel cell deuterium generator
Real name: Mark Rowley
Re: PEM fuel cell deuterium generator
Post by Mark Rowley » Tue Jun 11, 2019 5:59 am
Several of the Horizon PEM cell videos demonstrate gas collection in a syringe. If deuterium was collected in a large 100cc syringe, would the vacuum in a typical Fusor be sufficient to draw from it via a needle valve (resulting in the slow retraction of the plunger)? Or is it necessary that I have positive deuterium pressure?
Bob Reite
Real name: Bob Reite
Post by Bob Reite » Thu Jun 13, 2019 1:13 am
The vacuum would be more than enough, you don't need pressure. In fact the PEM cell has to be protected from excessive positive or negative pressures.
Post by Rich Feldman » Thu Jun 13, 2019 3:26 pm
Rex Allers has one of the PEM cell electrolyzers for refilling storage cartridges.
Puts out H2 even against back pressures of more than 400 psi.
As I've said before, maybe even in this very thread, there's no technical reason a membrane couldn't be supported on the hydrogen side, to withstand full vacuum. Then fusor gas flow would be controlled directly and immediately by the electrolyzer current setting.
