Vacuum Chamber Construction
Nicolas Krause
Real name: Nicolas Krause
Re: Vacuum Chamber Construction
Post by Nicolas Krause » Fri Jun 29, 2018 12:44 am
After a bit of a school enforced break, I've finally managed to find some time over the summer holidays to return to the machining of my vacuum chamber. Using a carbide spot drill, a pilot hole was drilled and then subsequently enlarged to 3/8 size with a number of drill bits. I now plan on using a step drill to enlarge the whole to close to its final size and finally a boring head to take the hole to the precise diameter. The second hole visible in the photos below is from an earlier machining attempt that didn't work out.
I do however have a question about workholding. I'm using 4 toe clamps on a tilting table to hold my workpiece in place. The hemisphere seems to come loose rather regularly with the setup. After monkeying around with it for a bit I was able to find a seemingly stable solution that held the workpiece securely, but I wanted to know if there was a better way to go about holding the hemisphere. Or if I'm simply setting up the toe clamps in a way that doesn't use them effectively.
Post by John Futter » Fri Jun 29, 2018 8:00 am
Toe clamps directly to mill slide bed
t bolt through the hole in the top with machined aluminium disc to fit hole now held top and bottom you will need to offset mill head to correct angle to bore hole.
enjoy
Nicolas Krause
Post by Nicolas Krause » Mon Aug 06, 2018 11:12 pm
Thanks for your suggestion John, I've cobbled together a better workholding solution as a result. A t-bolt in the middle of the hemisphere is connected to a long bolt, which has a couple washers on the end. I plan on adding a dab of superglue between the washers to hold them together as a unit and make assembly and disassembly of the work piece a little bit less finicky.
Nicolas Krause
Post by Nicolas Krause » Sat Oct 06, 2018 7:29 pm
Before returning to school I was able to complete the first angled port on one of my hemispheres. Now that I have the series of operations figured out I anticipate that I'll be able to complete the remaining ports much more quickly. I'll likely be able to get to it over winter break or failing that early spring once school breaks for the summer. A cheap step drill from china performed very well to rough out most of the hole and a boring bar was used to take it to final dimensions. Initially the boring bar was too long and excessive chatter resulted, but I switched to a much shorter tool and chatter was greatly reduced and surface finish improved drastically.
Post by Richard Hull » Mon Oct 08, 2018 5:10 am
Great work! You are using the exact same tilt table I use on my milling machine to do such work.
Nicolas Krause
Post by Nicolas Krause » Tue May 14, 2019 3:18 pm
After a school enforced break, I've managed to pass all my classes for the semester and have found some time to work a bit more on the machining of the hemispheres. I've successfully completed a second angled port on one hemisphere. What took me most of summer to finish with interruptions and mistakes in machining process took me the better part of an hour this time. I anticipate I'll be able to finish the remaining ports within the next few weeks. Then I can move on to learning to how to TIG weld!
Nicolas Krause
Post by Nicolas Krause » Thu Jun 13, 2019 6:13 pm
Machining has been completed on one hemisphere and the angled ports have been started on the second hemisphere.
Post by Richard Hull » Fri Jun 14, 2019 6:13 am
Gee! That is some aggressive machining with ports-a-plenty.
I trust once the flanges that hold the system halves together are welded, that you have clearances for the ports, which I assume are CF stubs.
Nicolas Krause
Post by Nicolas Krause » Fri Jun 14, 2019 6:49 pm
Yes, I'm copying Andrew Seltzmann's design that he's posted on his website. I doubt my machining tolerances are as good as his though, I've been using an edge finder and tilting table instead of the precision rod and indexing head setup he used. I've got a single half nipple CF port you can see partially hidden in the photo. I've been using it to test fit as I machined out the port holes. I've checked the port against the flanges which I also have and all fit quite well.
I figured that 10 ports would allow for some flexibility, it seemed a waste to build a vacuum chamber and then not be able to reconfigure it if in the future I wanted to monkey around with sputtering or semiconductors or some other project requiring high vaccuum.
I have the following general plan mapped out for the fusor chamber.
2 On Axis Ports:
TurboPump Connector
High Voltage Feedthrough
8 Off-Axis Angle Ports:
Pressure Sensor
ViewPort
Hydrogen Ion Gun
Boron Ion Gun
Quadrupole Mass Filter - based on Rapp Instruments design posted here
3 spare ports
I view this project as a rather long term thing for educating myself and gaining useful skills, I'm not planning on attempting Deuterium based fusion, many people have succeeded at that on this forum and I would like to try something new. If at the end of this none of my ideas work out I'll merely have gained a bunch of useful skills, which I view as a pretty good deal. My plan for the next year or so is to complete the chamber, power supply and high voltage feedthrough, and pump system. This will allow me to generate a plasma, and then I can begin working on the more advanced components. While I have most of the individual components all require some work, for example I have a small turbopump however I have to design a controller for it as I don't have the funds to purchase one new.
Post by Richard Hull » Fri Jun 14, 2019 8:58 pm
You are doing it the right way and the best way. Do a little and learn a lot. Do a little more, read and practice the skills. You will succeed in fusing even if your ideas don't pan out. As you note, it is a win for you that will give you skills for a lifetime of future endeavors. Each skill is another tool... a tool that you can't go to the store and buy. The "hands-on imperative" is ingrained into all doers.
