I have in the past made fusor vessels (at least for demo purposes) out of surplus pressure cookers. The first had a single pass through in the bottom of the pan. I have since moved to placing the feedthrough(s) in the lid so that I do not need to reach to the bottom of the pan to work on the feedthrough/ electrode.
Secondly I have in the past depended on the normal gasket and retaining tabs with positive external atmospheric pressure to seal the gasket. This works most of the time, but I wondered if the seal could be better. The picture shows using blocks on the lid tabs to raise the surface up to where C- clamps can provide compression. This is more like bolt compressed seal on chambers. The black sand was sprinkled on partially melted nylon blocks cut from a kitchen cutting board. Also the blocks were sanded to a trapezoidal cross section shape. This combination prevented the clamps from sliding off of the beveled lid. I originally thought about building a wood collar in two pieces to hold the lid down against the pan/ gasket. But the C- clamp approach was easier and seems to work well.
In this pressure cooker I was achieving best vacuums of ~ 25-30 Microns with a small diffusion pump. With the clamps tightened to moderate pressure I obtained a vacuum of about 12 Microns. I may have achieved slightly better vacuums if I had conditioned this two quart chamber for more than a few days.
D. Tibbets
Variations on Pressure Cooker Fusor
Re: Variations on Pressure Cooker Fusor
Looks like a good vacuum to me. You don't see those faint fine rays until well below 20 microns. Nice work!
- Rich Feldman
- Real name: Rich Feldman
Hooray for Dan.
Good demonstration of using nontraditional parts for fun, artistic, and/or practical reasons.
