Rules for Claiming Fusion Clarification
Re: Rules for Claiming Fusion Clarification
I will go there and add that rule as well. It was mostly generated as our youngest fusioneer had a great system and I wanted to see if he was for real. He was.
Edit:
I just checked and in part 2 line section ( a) I already had a note that a photo of the fusor and claimant is requested.
I did update and add a few lines to the old 2016 rules and moved it to the top of the pile in admin and construction forums.
viewtopic.php?f=47&t=12424
I even mentioned it in the dramatic example
viewtopic.php?f=18&t=7893
