DIY: Peltier Cooler Based Cloud Chamber
Post links to other interesting fusion or alternate energy sites here.
Edward Miller
Real name: Edward Miller
Post by Edward Miller » Tue May 11, 2010 10:14 pm
Very cool DIY cloud chamber here:
http://nothinglabs.com/cloudchamber/
"Cloud chambers let you see paths left by radioactive particles as they pass through a supersaturation of alcohol vapor. Vapor trails are formed when the radiation ionizes the alcohol.
They need to be very cold (about -15f) - so most designs require dry ice.
This design uses inexpensive electrical "Peltier" coolers instead. Unlike other peltier-based cloud chambers - it does not require ice water to operate.
See the Make a Cloud Chamber using Peltier Coolers (Instructable) for full details on making your own.
It's fairly easy to construct - and should only cost about $100 (less if you use a cheap ATX power supply)."
Instructable here: http://www.instructables.com/id/Make-a- ... r-Coolers/
Re: DIY: Peltier Cooler Based Cloud Chamber
Post by Chris Bradley » Wed May 12, 2010 6:21 am
Thomas Rapp posted his Peltier cloud chamber results here, also;
viewtopic.php?f=13&t=5986#p34430
viewtopic.php?f=13&t=5981#p34425
