Salt Water as Fuel
Post links to other interesting fusion or alternate energy sites here.
Nanos
Re: Salt Water as Fuel - Dr. Roy's bio
Post by Nanos »
I thought the jury was still out on homeopathy and water imprinting ?
AFW
Post by AFW »
Only if it's still out on Astrology and faries at the bottom of the garden.
Chris Trent
Post by Chris Trent »
There is potentially a terribly useful purpose for a system like his.
If you'll notice the plasma arc is disassociating the water into its constituent atoms, and that the atoms are then recombining at the upper edge of the plasma as water once more. If you add some carbon to the mix you have what would seem to be a simple, high density, syngas generator.
No surplus energy is created of course, and the efficiency is questionable, but it is a novel conversion method.
It all boils down to hype and absolutely no presented data from controlled tests. This is the stock and trade of the new energy freaks. The ones that do supply data have often used the wrong instruments in a wrong manner or botched the test in any number of ways.
Return to “Interesting Links”
