New Scientist on ITER
Quantum
Re: New Scientist on ITER
Post by Quantum » Sun Oct 18, 2009 11:36 am
The figures I qouted may not be entirely correct regarding density.
It's not MY theory, Carl.
I'm just saying the reason stainless steel is used for these applications is due to it's properies, which are due to it's structure, and theredore the figures you quote for Iron are irrelevant in this instance.
I'm not a mathematician, I'm just saying your theory is incorrect in this instance
You are effectively comparing chalk with cheese. Both contain calcium, but both have different properties.
Carl Willis
Real name: Carl Willis
Post by Carl Willis » Sun Oct 18, 2009 11:50 am
Don't worry, that's understood...
Indeed. Because of the properties.
I heard you the first time (and made the point that it wasn't my theory). But you must have an alternative that you feel IS correct?
Doing this same calculation for stainless steel is not conceptually any more difficult than with iron, and as far as my education tells me, makes use of exactly the same "theory." If you know the alloy in use at ITER and can do the work of looking up the 14-MeV neutron cross-sections for the constituents, we will compare "cheese to cheese." Only if you want to, though.
Carl Willis
TEL: +1-505-412-3277
Quantum
Post by Quantum » Sun Oct 18, 2009 11:59 am
I neither claim to know the figures for 440 stainless steel, or where to look them up.
I'm just saying you can't just assume the figures for Iron can be substituted.
And my knowledge relates to (specifically) 316 stainless. But it is reasonable to assume that 440 stainless will also differ from Iron.
Post by Steven Sesselmann » Sun Oct 18, 2009 12:07 pm
Thanks again Carl,
Yes I did figure that out, I was just puzzled about the variation in the crosss section, which you have explained.
For DD fusion neutrons 2.45 mev, the cross section appears to be around 3.3 barns.
So around 86% of the neuts would make it through 53 mm of Fe56
ln(0.86) / ((-8.5e22) * 3.3e-24) = 0.53
So back to my relatively thick walled STAR cathode (5.0 mm 306 SS), the absorbtion of the cathode wall plus the dielectric oil could have been quite a bit more.
I think I need to go back and revisit this experiment, there are a number of things I can improve next time.
Thanks for teaching me the method, ...
Carl Willis
Post by Carl Willis » Sun Oct 18, 2009 12:08 pm
So to summarize, you think the theory I use is wrong. You can't explain how or why it's wrong, you don't offer an alternative, you aren't a "mathematician," you don't know the figures or where to look them up, you do have some ideas about what it's "reasonable to assume." Also, cheese and chalk.
Thanks for playing, Ash.
Carl Willis
Quantum
Post by Quantum » Sun Oct 18, 2009 12:17 pm
No, Carl, I'm saying you can't use the figure for Iron, and assume it's the same for 440 stainless.
Simple really.
Carl Willis
Post by Carl Willis » Sun Oct 18, 2009 12:31 pm
Whoa!
Did I use a figure for iron and assume it was the same for some kind of stainless? Or is that a manufactured controversy--a wee bit of trolling? To answer, we need to read my posts. (That CAN be a herculean task, especially if one has the eyesight and / or reading comprehension of a barnacle.)
>To calculate the mean free path of a 14-MeV neutron in iron (standing in as an example for a steel composition we don't really know)
Hmmm....standing in as an example?
And 440 stainless? Wherever did you come to the conclusion that this is the actual alloy in use?
Carl Willis
Quantum
Post by Quantum » Sun Oct 18, 2009 7:00 pm
I believe 440 was mentioned earlier in this thread, however, 316 is usually used for nuclear applications.
Post by Chris Bradley » Mon Oct 19, 2009 2:36 pm
FYI (and FWIW), just looking at older publications on ITER, all they say is "a ferritic/martensitic steel", implying a custom alloy "tbd", by my reading of it.
Oak Ridge National Laboratory (under the U.S. ITER Project) has been developing their own casting steel for the specific purpose for ITER and they have a candidate alloy under test at the moment, as far as I can gather.
maybe of interest:
http://www.ornl.gov/~webworks/cppr/y2001/rpt/121054.pdf
Reading between the lines on other documents, I suspect they're looking at a low chromium (9Cr-1Mo) martensitic steel and/or nanostructured steel like 12YWT 14YWT, MA957 or 14WT with dispersed Y2O3, Y2Ti2O7 and/or YTiO3 strengthening particles. Some combination thereof, I presume...
edit: just came across this whilst looking under the DoE contract #DE-AC05-00OR22725 that may spill a few more beans on the subject;
http://www.ms.ornl.gov/programs/fusionm ... 012-24.pdf
Quantum
Post by Quantum » Mon Oct 19, 2009 4:36 pm
Ferriic/martensitic sounds like 400 series to me. Certainly not 300 series (Austenitic).
