I want to create a large population of deuterons from D2 gas at 1-10 Pa (then I intend to try higher pressures) via some mechanism. But I don't know what mechanism yet. Something that a hobbyist could build or buy on eBay or scavenge...
First I thought about using electron bombardment. However, it seems tricky all this with Tungsten filaments, that need to be activated and coated etc.
UV-light would probably not work. However a UV-laser would. The question remains of course how large the population of deuterons actually would be. The beam is narrow and the cross section for complete ionization/fragmentation of D2 is perhaps not so great.
One method I thought about is simply an electric arc across two electrodes. And then switch it off. There will then be (probably) a significant deuteron population for some time, because recombination to molecules and atoms takes time.
And I should add what I intend to do with the deuterons; apply an electric field of several kV across the plasma and observe if fusion happens.
The volume of plasma with deuterons should be relatively large (a cubic centimeter or larger) and also as cold as possible. Electrons may be quite warm as long as the deuterons stay cold. Electron bombardment should create such a situation.
Any input welcome!
Sven
P.S. Robert Tubbs has already done this and filmed it. Check out his "DC Magnetron Ion Source" on YouTube. First the ion source is on (only). No fusion. At 00:35 he turns on the extraction voltage (the main grid; 50-70 kV?) and there is fusion galore; see the snowstorm!
Brainstorming on creating deuterons!
- Real name: Sven Andersson
Jump to
- Announcements
- ↳ Announcements and Site Administration Topics
- ↳ The Fusioneers
- Start Here
- ↳ Frequently Asked Questions (FAQs)
- ↳ Please Introduce Yourself
- ↳ New User Chat Area
- The WaterStar Project: Finding the Trailhead
- ↳ Philo T Farnsworth Archive
- Images and long term fusor.net contributors
- ↳ Images du Jour
- ↳ Compilations of long term fusor.net technical contributors
- Theory
- ↳ Fusor and/or General Fusion Theory (& FAQs)
- ↳ FAQs: Fusion and Fusor Theory
- ↳ Other Forms of Fusion - Theory, Construction, Discussion, URLs
- Construction / Technical Do not post simple questions here. Use the New User Chat area
- ↳ Fusor Construction & Operation (& FAQs)
- ↳ FAQs: Fusor Construction & Operation
- ↳ Vacuum Technology (& FAQs)
- ↳ FAQs: Vacuum Technology
- ↳ High Voltage - Fusor Input Power (& FAQs)
- ↳ FAQs: High Voltage
- ↳ Neutrons, Radiation, and Detection (& FAQs)
- ↳ FAQs: Neutron - Radiation Detection
- ↳ Ion Gun Design and Construction (& FAQs)
- ↳ FAQs: Ion Gun Design and Construction
- ↳ Control and Instrumentation Hardware and Software
- ↳ Advanced Technical Discussion Area
- Miscellaneous
- ↳ Fusion --- Past, Present, and Future
- ↳ Interesting Links
- ↳ Files
- ↳ Books & References
- The Trading Post
- ↳ Primary Sources for Fusor Related Items
- ↳ Items For Sale
- ↳ Items wanted
- The early beginnings of fusor.net
- ↳ Songs Archive
- ↳ Intranets Archive
