I was just wondering whether or not an idea of mine could work for neutron detection. Any input would be greatly appreciated.
I embarked on a small project recently making a cloud chamber with peltier tile cooling. Had a lot of fun doing it, and turned out with successful results. (https://drive.google.com/open?id=0B3Nx7 ... UJ3QjJyTVE) - NOTE: Ionization trails are not extremely pronounced but water cooling of the peltier tiles themselves would cool the floor of the chamber more and create more clear ionization trails.
To my knowledge, silver activation releases beta particles (I was detecting alpha particles from Americium in this cloud chamber, which heightens the need for water cooling if I were to clearly see beta particles) and so should be able to detect the activation of silver in a cloud chamber.
Is this a viable neutron detection method? There is a silver nitrate reaction to coat glass with silver - after being passed through a neutron moderator, could neutrons be detected by a cloud chamber internally coated with silver?
Thanks,
Theo
Cloud Chamber
- Real name: Theo MacMillan
Re: Cloud Chamber
Silver activation requires lots of neutrons. Jon Rosenstiel used a cloud chamber years ago to detect proton recoil from fast neutrons, but his fusor does well over a million neutrons per second, isotropic. (Recoiling protons make thick heavy, alpha particle like tracks).
Only a test would tell the tale here. You would have to run the experiment with a working fusor nearby. (very, very nearby....)
Re: Cloud Chamber
Thanks, I'll get on that.
Theo
Theo
