Bubble vs. Quantrad Ranger Plus
- Real name: David Kunkle
No neutron detector yet, but I had been assuming I'd get a bubble detector. They're only good for 6 mos., and at this point, my project could easily go on for over a year- meaning $500+ worth of bubble detectors with nothing but paperweights at the end.
I have the chance to get a 2007 Quantrad Ranger Plus for about $1500. Uses a He3 proportional counter- 4" long and 1/2" diameter. Gives cps readout among lots of other things. Needs a Bi207 source for calibration. A chunk of money, but since it's already used, should be worth what I paid for it at the end making it far cheaper than bubble detectors.
Any comments before I do something I'll regret, and how hard to find a Bi calibration source?
Ernest Rutherford
Ernest Rutherford
Re: Bubble vs. Quantrad Ranger Plus
A true, radioactive neutron source can't be readily purchased by an individual. Period. They are limited to special NRC licensed users only.
David,
The $1500 is not an expense, it's a capital equipment cost. On the books of a business, it would have to be depreciated over some number of years.
Will you be able to get most of your money back by selling the detector some day, if nothing bad happens while it's in your custody?
- Bob Reite
- Real name: Bob Reite
You can send it to a calibration lab that has the necessary source. It should not cost more than $200.00 plus shipping both ways. The calibration should be good for several years as long as the instrument is treated gently.
Forgot about that. Must have been thinking about radioactive ores that people collect.Richard Hull wrote:A true, radioactive neutron source can't be readily purchased by an individual. Period. They are limited to special NRC licensed users only.
Ernest Rutherford
Ernest Rutherford
Not really a business expense in my case. But as usual, I'd be taking a chance it doesn't implode on me. Kinda like that first turbo I got that is now a high tech doorstop. Other than that, I imagine it'd still be worth close to what I paid for it.Rich Feldman wrote:David,
Ernest Rutherford
Ernest Rutherford
Assuming there's no actual damage to the unit (it appears to be functioning properly), it has a factory calibration stored in memory. Maybe use it as is, until I start registering neutrons, then I would want to send it off for calibration. What might the odds be that it would be so far off, it would not even register any neutron count from a fusor?Bob Reite wrote:You can send it to a calibration lab that has the necessary source. It should not cost more than $200.00 plus shipping both ways. The calibration should be good for several years as long as the instrument is treated gently.
Ernest Rutherford
Ernest Rutherford
As reported many times here, absolute neutron numbers are not a must have and are nearly impossible to obtain to within 10-20% with even the best gear in amateur hands.
A good detector or detection method is the key. Relative measurements with good detection gear are the very best the raw beginner might hope for. Run-to-run improvement in operational performance are easily obtained to within 5% or better.
Factory calibration is OK, but in many instances, a needless expense. A very, very old instrument might benefit from a modern calibration. I sent off an old Eberline counter some years ago that was new in the late 60's or early 70's and spent the big bucks. When it came back the numbers from a local source were not statistially different than when I sent it off.
Thank you for several good points in there. Well taken here- mostly as good news. No real point in tracking down a calibration source or paying someone to do it then. I take it form your post that, except in some sort of extreme case, true counts would be off by a percentage and not orders of magnitude which is what I would be most concerned about. Am I assuming too much?
Ernest Rutherford
Ernest Rutherford
The trick to measuring neutrons is to be sure you are measuring them and not some other radiation. We have discussed at length how to show yourself that you are measuring neutrons. Tricks that can help you to be sure. Too many people just never read the FAQs on how to do this.
I'll have to re-read those. I have read ALL the FAQs, but it's been a while.
Anyway, I've decided against the Ranger. Looking at the manual closer, it appears that the count maxes out at 65,000 and won't go any higher. Seems it's designed more for identifying isotopes in the field than for research. Thanks again for the help. Off for vacation for a week.
Ernest Rutherford
Ernest Rutherford
I find that the sodium iodide detector part of the Quantrad Ranger needs calibrating frequently, and daily testing. There's a backdoor manual way to do it with Cs-137 but you have to take the cover off to do it. I wrote that up maybe 10 years ago, it should still be on the web.Bob Reite wrote:You can send it to a calibration lab that has the necessary source. It should not cost more than $200.00 plus shipping both ways. The calibration should be good for several years as long as the instrument is treated gently.
The He3 neutron detector is a good one and fairly sensitive, as the whole design was done at LANL and licensed out for manufacture to the private sector (no longer made or supported evidently).
The isotope identification program is superb and adjusts it's time factor depending on the strength of the signal, and statistical confidence levels. A typical check source can be identified in 10 seconds, as long as it is in the library.
Overall not as good detecting Gammas or Neutrons as the SAM 935, which can be used with standard software control.
Quantrad Ranger Plus info:
http://www.qsl.net/k0ff/01%20Manuals/Qu ... er%20Plus/
George Dowell
- Real name: Richard Meek
Mr George Dowell,I find that the sodium iodide detector part of the Quantrad Ranger needs calibrating frequently, and daily testing. There's a backdoor manual way to do it with Cs-137 but you have to take the cover off to do it. I wrote that up maybe 10 years ago, it should still be on the web.
I own a Quantrad Ranger Plus and cannot purchase Bi-207 for calibration as it is not exempt. I would appreciate the instructions for the back door calibration with Cs-137 very much! Thank you.
I'll have to look it up, it's been maybe 10 years since my work with that.
Meantime do a gamma scan of Cs-137 and show me the screen. Specifically where does the 661.7 peak show up?
Thanks
Thanks
George Dowell wrote:I'll have to look it up, it's been maybe 10 years since my work with that.
Thanks
richardmeek wrote:George Dowell wrote:I'll have to look it up, it's been maybe 10 years since my work with that.
Thanks
In case it's of any use, that big spike (according to the Ranger) occurs at 313-319 KeV. I'm borrowing the thing from Richard and thought I'd do the scan again for kicks.
If it's not possible to calibrate with Cs, perhaps it would be possible to non-destructively hack a pulse output jack into the amplification stage for the Scintillation tube of the ranger somewhere and use it with PRA?
