Driving a deuteron accelerator with a stungun voltage source
Grigory_Heaton
Real name: Grigory Heaton
Post by Grigory_Heaton » Fri Oct 21, 2016 5:08 am
Yet another idea I want to run by those who know more about this than I do.
You can purchase a stun gun on Ebay incredibly cheaply, for less than $20 in almost all cases. They essentially produce a tiny current at a huge voltage for a short period of time, usually consuming 1-2 Joules per burst. Notably, I found one that runs at 100,000 volts (and therefore only produces current on the order of tens of microamps in short bursts), although these voltages can go much higher with other stun guns. For reference, a taser runs at around 50,000 volts with a much higher current. Since such a measly power source in only short bursts could not be used for a full-on fusor, my hope here would be that one (or more) of these high voltage stun guns could be used to create a deuteron accelerator capable of fusing deuterium when hitting the target (basically a standard neutron generator) in small amounts, that operates in quick bursts. If functional it would be a very cheap (and small) option compared to the regular route of having to build or purchase a large voltage boosting setup.
Now 100 kV should be adequate for the deuterons to fuse if they impact another deuteron at the target. Whether or not enough fusion reactions occur to detect something in the short window that the voltage is being applied is another story, especially since the stun gun probably runs off a capacitor if I had to guess, which means that voltage is going to drop as it drains. But if there is a hint of this working I may try it, since it would cut the cost a lot (unless I'm missing something big).
Anyone think this is feasible? That high voltage for so little cost is very tempting even without the high power output.
Re: Driving a dueteron accelerator with a stungun voltage so
Post by John Futter » Fri Oct 21, 2016 5:48 am
Grigory
no stun guns are of no use
no stun gun produces 100kV.
no stun gun produces continuous DC
do not believe the avertising crap that they serve up to sucker people like you to buy.
Ion sources need around 1 -5 kV at up to 30mA. ie 10 to 150 watts continuous output
what acceleration potential you then supply is up to you --the more the better so another power supply of 20 -80kV 10 -30mA is required for the acceleration ie 200 to 2400 watt continuous output
all of this has been explained on this site in the approriate FAQ's
do some reading!!!!!!!
Re: Driving a deuteron accelerator with a stungun voltage so
Post by Richard Hull » Fri Oct 21, 2016 5:50 am
It simply will not work. The number of folks trying a HV workaround approaches infinity. Energy is energy, there is no way around it. Stun gun systems have no usable energy in them.
Read the FAQs!!!
