50kV Supply
Joe Gayo
Real name: Joe Gayo
Re: 50kV Supply
Post by Joe Gayo » Fri Jan 25, 2019 10:20 pm
HV Transformer and Multiplier are included (no driver)
Chris Giles
Real name: Chris Giles
Re: 50kV Supply
Post by Chris Giles » Fri Jan 25, 2019 10:34 pm
Thanks very much Joe
Re: 50kV Supply
Post by Rex Allers » Sat Jan 26, 2019 11:39 am
The ebay seller is 'bdmerchandise'. I exchanged some emails with him and he seems pretty helpful if not completely aware of details on all these parts.
I got my unit today (the same aluminum box that Joe told us about). As I suspected, and posted earlier in this thread, it looks to be Glassman parts that are based on their ER series supplys. The multiplier module in these boxes is indeed an ER-series part and the transformer looks to be the one used in ER supplies. The ER series is 300 W output.
They had many options, like this:
ER10P30 ER10N30 ER10R30 0-10kV 0-30mA
ER15P20 ER15N20 ER15R20 0-15kV 0-20mA
ER20P15 ER20N15 ER20R15 0-20kV 0-15mA
ER25P12 ER25N12 ER25R12 0-25kV 0-12mA
ER30P10 ER30N10 ER30R10 0-30kV 0-10mA
ER40P7.5 ER40N7.5 ER40R7.5 0-40kV 0-7.5mA
ER50P6 ER50N6 ER50R6 0-50kV 0-6mA
ER60P5 ER60N5 ER60R5 0-60kV 0-5mA
ER75P4 ER75N4 ER75R4 0-75kV 0-4mA
In those, P = positive output, N = negative, and R = both (I think for R, you had to swap the multiplier module to change between P or N.) In the part numbers, the first number (before P/N/R) is kV and after is mA, so the product of those two numbers is 300 (watts).
The units the seller is striping down, I think, are some kind of big complex security xray scanners. I think this HV part powered a small xray tube.
So it looks to me that Glassman sold some custom design components that is very close to the ER supply.
The seller sent me some pictures and it looks to me that he has boards that are ER main boards, except the place that usually has the transformer on the board is unpopulated and the transformer and multiplier have been moved to this separate aluminum box. I think the board and one of these boxes can be paired to make an equivalent to an ER supply. Not simple... you'd need to figure out how to connect AC -- pots for V and I control (or voltages) -- meters or monitors for V and I -- how to connect between the board and this box.
I have purchased one of these ER-looking boards from the seller but don't have it yet. I think he said he had 8 total units that he is stripping down. I think he might be receptive to selling a package with both this box and one of the driver boards.
I can try to share more about how it looks after I get the board. So far, what I'm sharing here just looks good in theory.
Joe made his own driver for the transformer and says he is getting 700 or more watts out (more than twice the 300 W spec). I'm not sure if it is possible to get that power out of the original ER-style board. At minimum, I think that would take some hacking to the current sense which is an input control to the 3525 switcher chip.
Here's a link to one ER manual that has schematics. All the versions are about the same except for the number of stages in the multiplier and the polarity orientation of the diodes.
https://docs.google.com/file/d/0B7IIDFX ... xXTDg/edit
Hopefully I can add more after I get the board. If you contact the seller, tell him Rex
sent you.
-Rex
Chris Giles
Re: 50kV Supply
Post by Chris Giles » Sat Jan 26, 2019 8:51 pm
Thanks Rex. That is most helpful, particularly the manual. The other manuals I have found have been similar but that one is exactly the right model (board part number matches). Looks like a complete unit could be re-created but would be quite a fiddle.
Joe Gayo
Real name: Joe Gayo
Re: 50kV Supply
Post by Joe Gayo » Wed Jan 30, 2019 6:18 am
Revised my driver. The frequency is lower(30KHz) and the peak switching power is around 1200W. The multiplier and transformer are quite robust in the Glassman stack. The new combination has my device around 1.5M n/sec at near full voltage/current.
Cristiano_Machado
Real name: Cristiano Machado
Re: 50kV Supply
Post by Cristiano_Machado » Wed Mar 20, 2019 4:06 pm
Hello,
Finally I received my unit. Now I am working on the driver.
I would appreciate your comment on my design. This is based in Joe's suggestion (http://www.loneoceans.com/labs/sstc2/), and Gao Guangyan's project.
Power inverter
The output will be plugged into the unit transformer.
Transformer
I am still working on the frequency generator to control the IGBTs.
Thanks for the help.
Regards,
Cristiano
Chris Giles
Re: 50kV Supply
Post by Chris Giles » Fri Mar 22, 2019 8:17 pm
HI Cristiano
I recommend that you purchase one of the control boards from the seller and use that as a start. Coupled with the HV box it makes a complete Glassman ER PSU minus the front panel components. It has a driver similar to your sketch. You can start from that and then try to hack it to get higher output.
If you choose not to, you can still refer to the schematic for it. Regarding your schematic, you should use a bridge rectifier, and also you would not need a Variac if you use a standard PWM controller/driver IC where you have shown "frequency driver".
Regards
Chris
Cristiano_Machado
Re: 50kV Supply
Post by Cristiano_Machado » Sat Mar 23, 2019 10:34 pm
Hello Chris,
Thank you for your feedback. I will check this board with the seller.
I completed the schematic, using my initial design. Now I need to figure out the value of interrupter's resistors and capacitor. I think 25 kHz and 40% duty cycle is a good start and it will not stress the unit.
Please fell free to comment and give any suggestion.
Regards,
Cristiano
