Hi, I have been searching around the FAQ's for an adequate power supply to power a real fusion reactor. I found two high voltage systems, and wanted some other user input to help me determine if they could be used for detectable fusion. The first: https://www.ebay.com/itm/SPELLMAN-High- ... 1438.l2649 The second: https://www.ebay.com/itm/Spellman-X2189 ... 1438.l2649 Now of course the second is a lot more expensive, now just know I am a high school student, and am working on such a budget. If these two are not viable for fusion can someone supply some good ideas, as to some other systems. All suggestions are welcomed.
-Miles
High Voltage Supply?
- Real name: Miles Hawley
Re: High Voltage Supply?
Look at the title of the section you are posting in:
"Construction / Technical --- Do not post simple questions here. Use the New User Chat area"
The simple answer is No and No on the supplies. (For multiple reasons.)
Repost your simple question in the New User Chat Area and I can reply with more reasons why they both are useless for fusion.
Sorry about that, I wasn't sure where to post this question. Won't happen again.
-Miles
-Miles
