Will a Sprengel Pump Work?
Re: Will a Sprengel Pump Work?
Post by Rich Feldman »
Yes, and Sprengel pumps were superseded by diffusion pumps driven by boiling mercury.
In the 1960's, Scientific American's classic Amateur Scientist columns had several projects for skilled, well-equipped amateur glassblowers.
Including a Hg-vapor diffusion pump.
I couldn't immediately find a picture of that, but here's a contemporary glass diffusion pump you can buy from svpneon.com.
Here's one homebrew Sprengel pump running on youtube.
https://youtu.be/viJ3T-1KZqY?t=641
Silviu Tamasdan
Real name: Silviu Tamasdan
Post by Silviu Tamasdan »
That's the same video I linked to earlier in the thread. Cody has several other interesting videos, including running a mercury still. Somehow he manages to do it safely without exposing himself too much to mercury (another video has his own toxicology test results for heavy metals in the body including mercury and lead).
Silviu did post that video link first, and I'm sorry not to have noticed sooner.
Here's my account of cleaning "dirty" mercury, obtained through craigslist from a local resident about 5 years ago. Since then the street price has gone way up. I think after a USA-and-Europe export ban, to discourage unhealthy and wasteful use by very poor people extracting gold in far-away countries.
Looks like some previous owner had been collecting Hg metal from various sources. Floor sweepings? Came to me in a factory-printed "Mercury, 10 lbs" bottle (about the size of a 12 oz soda can), mostly full. I bet the shrink seal on its cap was put on to discourage friends or children from playing with it.
It looked too scummy to behave well in glass capillary tubes, such as McLeod gauges. I found online links to many references, dating back more than a century, about cleaning and purifying mercury. Bet it still deserves the title "the purest metal" in commerce.
I cleaned about a pound of mercury by shaking, in a thick plastic bottle with corrugated sides and stoutly-threaded screw cap. Starting with soapy water or ammonia, then vinegar, maybe even dilute HCl, till the wash water was clear. The metal looked mirror-clean after that, and "pinholing" (look it up). I never made it fall in fine drops through a tall column of dilute nitric acid, nor distilled any under vacuum. (Hulett's method mitigates the problem of dissolved zinc coming over with the Hg.) Nor, yet, has any of my mercury entered a McLeod gauge, or even a thick-walled glass capillary tube procured for resistivity measurement.
Mercury is traded and priced by the 76-pound iron flask (since 19th century) and by the metric ton.
Who wants to compute the size of a metric ton, in a cylinder whose height and diameter are the same?
Silviu Tamasdan
1t=1000000g; divided by 13.53g/cm3 makes 73909.83cm3. V=pi*r^2*h; if h=d=2r, then V=pi*r^2*r/2=(pi*r^3)/2
r^3=2*V/pi, solve for V=73909.53, r=36.1cm or d=h=72.2cm.
Post by Rex Allers »
I think you made a mistake. You said
h=d=2r
but then you substituted r/2 for h
seems correct formula should be
r^3=V/(2*pi)
giving
d=h=45.5 cm
Silviu Tamasdan wrote: Sat Nov 18, 2017 4:04 pm 1t=1000000g; divided by 13.53g/cm3 makes 73909.83cm3. V=pi*r^2*h; if h=d=2r, then V=pi*r^2*r/2=(pi*r^3)/2
Is that your final answer? :-)
Rich,
Dang, even knowing what I was looking for, it took several tries on searches to find that container diagram. Nice work to find that.
Did you choose to ignore the correction I made for Silviu's simple mistake? His calculation seems right except for when he ignored his own value for h when he substituted.
From container dimensions: 508 - 2*10 = 488 mm = 48.8 cm
My corrected value was 45.5
If you are building a container, better to spec it a little big.
Real name: Dennis Brown
Post by Dennis P Brown »
Yes, a long detailed series of posts on this thread relative to Hg and its distillation and or/availability and weight/volume; uh, why again, one asks? Are we getting to be a Hg forum? ;)
Silviu Tamasdan
LOL that is why I usually triple-check my calculations. I didn't for this one. :)
And I feel that discussions of Hg in a vacuum subforum are A-OK. Hg is a useful metal if used wisely. Unfortunately I don't have any.
Rex, I think we both hit Send at about the same time. I wasn't responding to your answer. Didn't figure it out myself, or find that dimensioned diagram, until seeing the first answer (which is correct size for 4 metric tons).
The most recent round is doubly relevant at fusor.net. The big boys at Oak Ridge N. L. investigated mercury storage in preparation for their Spallation Neutron Source. Most productive in the world, excluding nuclear fission reactors. A search for ornl spallation will do. My initial search was metric ton mercury container.
The 76-pound "flask" unit of measurement probably dates to long before the 19th century. I bet it's connected to an early Spanish or even Roman unit for commerce, used long ago around the Almaden mines in Spain.
https://minerals.usgs.gov/mineralofthemonth/mercury.pdf
Doug_Gourlay
Real name: Doug_Gourlay
Post by Doug_Gourlay »
Dennis P Brown wrote: Thu Nov 16, 2017 4:23 pm (even room temperature mercury releases a significant amount of vapor.) Y
If mercury did release significant amounts of vapor at room temperature, the Sprengel Pump wouldn't work.
The high vacuum that results is due to the low vapor pressure of mercury, at room temperature.
Depth of vacuum is, in part a function of the vapor pressure of the material used to create the vacuum.
I used to use Santovac, many years ago. The vapor pressure of Santovac 5 at 25 degrees C determined by extrapolation of higher temperature data is 4 x 10-10*
Doug
*https://www.sisweb.com/vacuum/sis/satovc5.htm
mercury is 2.58×10 −6 atm
Santovac is great stuff if you have hundreds of dollars for your diff pump fill up. This now ancient post got a restart with the thoughts of $400 santovac refill suggestions.
I am stunned this topic and its related ancient pump topic relaunched.
Alex Aitken
Post by Alex Aitken »
I did a lot of searching, I assume before this thread existed because I haven't read it before. I think it was in response to the French guy that made vacuum triodes with a Sprengel pump.
Low melting alloys stick because of an oxide layer that forms on the liquid metal. Additives, like antimony can help but not stop this. They universally destroy the pump when they freeze. Some alloys that are documented to freeze without an increase in volume actually do initially expand and then the solid shrinks over a few hours. There is a 'magical' galinstan that is supposed to freeze at -19C or thereabouts, but the company that makes it for thermometers doesn't sell that version only the normal one. -19C is only claimed to work in a vacuum, so it may be supercooled and not a real freezing point. The method used to stop it sticking to the glass is to make sure no oxygen enters the system, there is no coating.
Organic/Fluorine based liquids dissolve gasses quite well, especially oxygen. To me this suggests organic liquids are not workable.
The tube in a Sprengel pump does not last, the point at which the falling drop hits the liquid is subjected to a lot of stress and it fatigues and ultimately breaks.
Pumping speed is very very low. Operating a fusor by pumping at the same time as bleeding in deuterium to keep the gas clean and flush out crap in the chamber doesn't sound feasible.
It's a cool and simple design but there is nothing special about a Sprengel pump, it's classed as a mercury sealed mechanical pump, it's just that the pistons are a drop of mercury.
I do not want to use mercury, and I gave up trying to find an alternative in the lit.
Chris Seyfert
Post by Chris Seyfert »
Since this thread was resurrected, for historical and educational purposes I've attached an excellent paper on a particular variant of the Sprengel pump. It also goes into the history of vacuum pumping and why the Sprengel pump in general fell rapidly out of favor.
1972 Myer forgotten Sprengel pump.pdf
(632.51 KiB) Downloaded 268 times
